-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   When should you replace a transom due to rot? (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/361231-when-should-you-replace-transom-due-rot.html)
airbats801 06-14-2019 07:01 PM
I decided to check my 86 scarab panther out today, I noticed up at the very top where it meets the aluminum bumper trim, and about 4 inches in from either side of the top corners, and maybe 1 to 2 inches down its dull, and it's also a bit dull around the exhaust ports. Everywhere else around the tabs, and drives is nice and solid though. Should I be too worried yet? I would like to get away with another season before diving into this thing, but I am pulling the engine this evening to upgrade to the 72c velvet drives, and I do plan on checking around the stringers.
242LS 06-14-2019 09:31 PM
How did you measure that? What does "dull" mean?
airbats801 06-15-2019 02:26 AM
sorry nothing technical, just the hammer method
Crude Intentions 06-15-2019 04:19 AM
If it’s rotten replace it. If it’s just wet but solid it’s ok for now
airbats801 06-17-2019 01:16 AM
THanks, It's dry from what I can tell. I took a pick and tried picking around the exhaust ports, it was good and solid, and dry as a bone. It actually looked very good. I had a hull survey done and was told it was good a few years back when I bought it, but quite a bit of water built up inside it while it was parked outside this last winter, and it got me a bit nervous.
