Checkmate Wiring Schematic? >
Old 12-09-2007 | 07:57 AM
Default Checkmate Wiring Schematic?
Alrighty - I'm about to mate two Gen V 454 with and '89 Checkmate with all original wiring, including twinned and differential tachs, trim and K-plane switches and don't have anything to go on other than good luck and a dream.
Anybody have anything, even a generic loom diagram?
Attached Thumbnails Checkmate Wiring Schematic?-engine-bay.jpg   Checkmate Wiring Schematic?-2x454%40607cochise.jpg   Checkmate Wiring Schematic?-cockpit.jpg
nwimbush is offline
Old 12-18-2007 | 08:59 AM
Wally's Avatar
Were doomed!
Heres a generic list of color codes i posted years ago...this will help you:
Blk -Grounds-General
Blk/Brn -Pump Grounds
Blk/Red -Voltmeter Grounds
Blk/Org -Isolated Accessory Grounds
Blk/Yel -ignition stop
Blk/Grn -Water Level Sender Ground
Blk/Blu -Lighting Grounds
Blk/Gry -Nav Light Grounds
Blk/Wht -Battery Parallel Solenoid
Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
Brn/Red -Pumps, Bilge or Sump
Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
Brn/Yel -Baitwell or Aerator
Brn/Grn -Fresh Water Pump/Water Maker
Brn/Blu -Head Pump
Brn/Vio -Washdown Pump
Brn/Wht -trim pos sender
Red - Battery Feeds Unprotected
Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
Pink -Fuel Sender
Org/Blk -Audio System Feed
Org/Brn -Electric Head-Sanitation System
Org/Red -Wiper Port
Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
Org/Yel -Diesel Pre-heat
Org/Grn -Wiper Stbd
Org/Blu -Communications Equipment
Org/Vio -Navigation Equipment
Org/Wht -Wiper Center
Yel/Blk -Choke - Neutral saftey trans mounted
Yel/Red -Start Solenoid(starting circut), Neutral Safety
Yel/Org -Powered Ventilation, Fans
Yellow -Bilge Blowers -(also alternator DC output)
Yel/Wht -Rudder Angle Sender
Grn/Red -Stop Solenoid/Kill Switch
Grn/Yel -AC Grounding
Green -Bonding
Grn/Wht -Engine Trim in and or tilt down
Grn/Org -Engine Independent Trim down
Blu/Blk -Cabin Lights
Blu/Brn -Oil Temp Send
Blu/Red -Cabin or Cockpit Lights Port
Blu/Org -Engine Independent Tilt Up
Blu/Yel -Lighting Circuits to Remote Send
Blu/Grn -Cabin or Cockpit Lights Stbd
Blu -Instrument & General Lighting
Blu/Vio -Courtesy, Boarding Lighting
Blu/Wht -Engine Trim Outand/or Tilt Up
Light Blue -Oil Pressure
Vio/Red -Eng. or Generator B+ from Breaker
Vio/Yel -I/O Trim Up (ballast bypass)
Vio/Grn -I/O Trim Down
Vio -12v Ignition-Generator or Engine
Vio/Wht -Trim "Trailer" switch
Gry/Blk -Mast Light
Gry/Red -Spotlight Remote
Gry/Org -Docking Lights
Gry/Grn -Strobe or Beacon
Gry/Blu -Spreader/Flood Lights
Gry/Vio -Windlass/Winch
Gray -Navigation (running) Lights, Tach. Send
Gry/Wht -Anchor Light
Wht/Brn -Temp. Alarm or Indicator
Wht/Red -Fuel Alarm or Indicator -((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Org -Fire Alarm or Indicator
Wht/Yel -Air Flow Alarm or Indicator
Wht/Grn -Water Press/Flow Alarm or Indicator - ((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Blu -Oil Press Alarm or Indicator
Wht/Vio -Voltage Alarm or Indicator
White -General Alarm Usage, Yamaha Kill Switch
Tan - Water Temp sender
Tan/Blu -Warning system sense wire (Audio warning)
Pink -Fuel sender
-Wally
Wally is offline
Old 12-18-2007 | 10:05 PM
Default Wiring from the aft - '89 Checkmate 28'
Thanks, Wally, it will. I also found this BBC wiring diagram from Hardin that matches my old looms, and your color codes.Nice match.
I'm looking for a schematic to help me with understanding the tachs, k plane switches and trim switches wiring, but that won't stop me from figuring it out when I need to.
nwimbush is offline
Old 01-02-2008 | 08:33 PM
Anybody know how to wire in a one wire alt.
27 MAGNUM is offline
Old 01-05-2008 | 12:10 AM
Connect "the wire" to the battery +
nwimbush is offline
Old 01-05-2008 | 07:59 PM
How do we get Alt Output signal to volt meter gauge
Old 01-05-2008 | 09:34 PM
voltmeter-positive to ignition switch on position
voltmeter -negative to ground
jsmagnum is offline
Old 01-06-2008 | 07:40 AM
Anyone know if the original twin engine setup came with one or two alternators? If two, was there a diode circuit to prevent backfeeding the weaker alternator, or did one serve the auxiliary equipment and one the engine loops?
nwimbush is offline
scottie150
Scarab
9
04-14-2008 12:12 AM
OldEliminator
3
08-27-2006 10:53 PM
wwwTOPDJcom
0
08-07-2005 09:19 PM
BDFREE
11-22-2004 08:21 AM
cig1988
9
07-16-2003 04:01 PM
