-   -   new steering pump (https://www.offshoreonly.com/forums/do-yourself-boating-budget/178626-new-steering-pump.html)
nocigarette 01-30-2008 08:21 AM
new steering pump
I have almost pieced together all the parts i need for a steering system (full hydraulic).......
My question is will a stock gm power steering pump work, i have been told that ya need to drill out the exit side of it for more oil volume, what else is there besides that????
KNOT-RIGHT 01-30-2008 08:43 AM
KRC makes all different pumps.
nocigarette 01-30-2008 11:26 AM
Who is krc
KNOT-RIGHT 01-30-2008 12:18 PM
Here ya go dude!
http://www.krcpower.com/
The Saginaw pump is basically a gm p/s pump.
I have found the actual Marine version on EBay
for less then half the cost from merc.
Good luck
nocigarette 01-30-2008 02:27 PM
WOW cool site thanks a lot..................
f311fr1 02-02-2008 02:42 PM
You also need to change the shims in the relief valve to raise the pressure.
offthefront 02-02-2008 05:01 PM
I added Imco full Hydraulic the past year and did nothing to the pump (stock) and it works great .... not saying its right but it works perfect ...m
hallj 02-10-2008 10:06 PM
The factory GM pump will work, What's the operating pressure of your steering system?
jeff
shoregasm 02-26-2008 01:12 PM
factory pumps will not work ! they may last for a few days but you WILL see failure and hopefully it will not be at high speeds...
What you will see for sure is at high speeds the steering will act "weird" and respond slow, then "jerk"....just like if you had low oil level...guess why ? lower oil pressure and volume level then required by system....don't make this mistake, it may cost you more in the end
nocigarette 02-26-2008 11:34 PM
I know of at least two threads on here loaded with guys that will disagree with you......As long as you change the valve in the back of the pump to your stock merc pump they are exactly the same.............
