Changing water pumps
Whats involved in changing the water pumps on 250XS's with Sportmaster gear cases? Is one pump kit better than another. I have all tools and can use them. Thanks
Use the Merc assembly's and you'll be fine.
Water pump change
No one knows how to change a water pump in a Sportmaster gear case?????
Originally Posted by Frank Galasso
(Post 2469778)
You need instruction? |
Water pumps Sportmaster
Originally Posted by Trippin
(Post 2469787)
4 nuts on cavplate, 1 under torque tab, drop lower unit, remove the 4 nuts on waterpump housing, remove housing, impeller and keyway, replace all with the contents of your new kit, housing if necessary. Apply a light coat of oil or soap to housing. Slide impeller down onto wearplate and keyway install housing while turning driveshaft clockwise, tighten nuts on w/p housing. Re-install lower unit on midsection. That's it , more or less. You can do it.
Make sure you shift the drive into forward gear and turn the shift shaft counterclockwise befor installthe thelower unit
(Post 2472986)
Originally Posted by sunchaser796
(Post 2514694)
| All times are GMT -5. The time now is 10:20 PM. |
