-   -   trim tab problem..... (https://www.offshoreonly.com/forums/do-yourself-boating-budget/185782-trim-tab-problem.html)
007joe 05-01-2008 09:47 AM
okay real quick background.... ordered new tabs, no time to install, friend has shop say's no problem..... shoulda done myself...
heres what happened... i asked them to install 1/2 inch up as i was told, they dint, the tabs are flush with the bottom.... how bad is this?
next there are 4 mounting bolt holes, three along the bottom one on top.... they failed to install all three along the bottom only installed the outside two, how bad is this?
i plan on install the middle bolt but am a little worried about the finish and am curious how bad they screwed up!!:angry-smiley-038:
monstaaa 05-01-2008 07:05 PM
what type of tabs #1. yes you need all 4 bolts if they are k-planes. as for them being flush with the bottom, not good. can create a multitude of negative issues. porpousing, hook, grabing water, and so on.
what part of staten island?
007joe 05-01-2008 07:09 PM
they're eddie marine tabs.... they're e-planes, they dint put the center bolt in cause of a stringer in the way... now i dunno what to do .... i'm in willowbrook
jdub 05-01-2008 09:44 PM
Take them off before the 5200 sets up! Fill the old holes with 5200, move the tabs up 1/2", and put a lag screw in the center one with the stringer in the way.
jhiguy377 05-02-2008 10:28 AM
like jdub said
monstaaa 05-03-2008 06:38 PM
where are the tabs mounted in reference to the outer most chine?
and i have another location in staten island. you may be able to go there for some help. send me a private message and i ll give you some more info.
007joe 05-03-2008 07:05 PM
1 Attachment(s)
Hers A Pic Of The InstallAttachment 339914
Velocity Vector 05-03-2008 08:30 PM
Jesus!!
007joe 05-04-2008 09:08 AM
Originally Posted by Velocity Vector (Post 2546913)
Jesus!!
THAT BAD HUH? I GUESS I GOT TO GET TO MOVING THEM... IF YOU WANT SOMETHING DONE RIGHT YOU GOTTA DO IT YOURSELF!!
Velocity Vector 05-04-2008 09:54 AM
10-4 Since you already have holes in it you may want to go up 1" instead of 1/2" to get away from the other holes a bit more.
My plates came in yesterday, changing out to 28" plates.
http://i265.photobucket.com/albums/i...DSC_0006-3.jpg
http://i265.photobucket.com/albums/i...DSC_0004-4.jpg
007joe 05-04-2008 07:01 PM
I Was Gonna Go About 3/4 Inch Up And About 1.5 To 2 Inches Closer To The Center To Get Around The Stringer That They Could'nt
IN FILLING THE OLD HOLES AM I RIGHT TO INSERT A DOWEL SOAKED IN RESIN THEN GLASS EITHER SIDE AND PAINT OR IS THIS NOT SAFE FOR THE TRANSOM?
Jigsaw89 05-20-2008 03:30 PM
That's how I'd do it... based on the chronicles of Glassdave in the Fiberglass Forum.
hurleyr 05-24-2008 05:35 PM
You might want to run it first. Could be far enough above the running surface to not have the problems. Seems like a bunch of work if its really not necessary. My 2 cents..
007joe 05-24-2008 10:27 PM
hurley (and everyone else) I just ran it today for the first time... i had her up in the 60's and she felt fine also just at regular cruise speed, 40-45 she handled great! i dont think i have to do anything, thanks for all the help guys!
