-   -   new fuel spout 95 Baja 272 (https://www.offshoreonly.com/forums/do-yourself-boating-budget/188701-new-fuel-spout-95-baja-272-a.html)
rlong 06-11-2008 06:26 AM
Can anyone tell me how to get to the fuel neck to change or do i have to tear out the interer?
Griff 06-11-2008 11:58 AM
huh?????????
BDiggity 06-11-2008 01:02 PM
it runs from the gunwale under the flooring to the tank. u should be able remove the screws that hold the filler to the hull. i think the hose then connects to that filler. thats how mine was when i was poking around one time when running speaker wires.
Are you putting in a locking one or quick fill?
Griff 06-11-2008 02:06 PM
ahhhhhhh, now I understand what you're asking.
You have to go from the inside if it was done right. One of the screws through the neck should be through bolted and have a ground wire from the tank attached. The hose also needs to be double clamped.
rlong 06-11-2008 02:56 PM
I Am Replacing The Whole Thing Since I Lost My Cap And Cant Find A Replacementthe One I Found Looks Just Like It But The Cap Threads Are Different So I Have To Pull And Replace The Whole Thing Instead Of Just The Cap I Pulled The Glove Box But Will Have To Drill Big Hole To Get To It Other Option Looks Like If I Tearout My Speaker And Part Of The Wall Looks Like I Could Get To It Just Wandered If Any Had Done This
Griff 06-12-2008 03:53 AM
There should be a way to access it from somewhere with cutting a hole. They had to install it somehow and be able connect the hose.
rlong 06-12-2008 06:24 AM
Best shot i think i see is removing some panels in the corner of the cabin i will try this this weekend
