Originally Posted by stevemamanfountain
(Post 2593370)
what is the correct gap for he plugs ? i will make sure they recheck them one bu one !
once the intercooler is back, we will have the fellow install a mechanical fuel gage to really see what pressure it is showing. |
Originally Posted by kennyo
(Post 2593543)
Good idea on the gauge. P/C says .028-.030 with a stock ign. If you run @.035 it will probably miss on the top end or under load. I run mine @ .030 AC MR42T's.
Originally Posted by Bryan Rose
(Post 2594143)
Ditto...stock run @ 20 -25 if you have MSD 35
my pyrometer gage is not moving ...gage is fine. seems like the sensor on the motor is not sending signal. anyone know where i can locate that sender ? |
(Post 2601284)
thanks. i put a 35 gap on the plugs as i am also with an msd.
| All times are GMT -5. The time now is 10:41 AM. |
