-   -   454 cam swap questions... (https://www.offshoreonly.com/forums/do-yourself-boating-budget/197545-454-cam-swap-questions.html)
PROGRESSIVEAUTO 10-20-2008 07:01 AM
Looking to swap the cam and valve springs out of a 1992 310 hp 454. This valvetrain appears to have positive stop rocker studs.[non adjustable] Guide plates say MARK V on the top sides. I would like to run somthing similar to a 500HP cam but prefer not to convert to a roller cam and really do not want to change the studs out. Any input would be GR8 from all reputable sources. Thanks Guys!
Griff 10-20-2008 12:22 PM
Go with a cam similar to a 454 mag cam or maybe a little larger. The heads won't flow enough to support a big cam. You need to go with new studs for the rockers if you go with a larger cam. You will probably need different valve springs as well. If you go with a cam over .550 lift, you will need roller rockers as well. Your best bet is to just go with 454 mag cam or similar.
jw454 11-04-2008 08:21 PM
The Gen V standard duty has peanut port heads and will not flow past 4000-4500 rpm. and cant possibly make power at or above that rpm range with the stock exhaust. Look for a cam in the range of 205-218 [email protected] .480-.500 lift at valve and112-114 lsa. A cam profile in this range will make lots of torque. JW.
speedreeder 11-05-2008 12:36 AM
I have two sets of the conversion studs so that you can use standard rocker arms. I also have two complete sets of stock rockers and balls, nuts for the adjustable type rocker arms. I put these on several motors and then used 1.8 roller rockers with the stock cam and would gain 300 rpm on the average for a twin engine set up. PM me for a price or if you would like any other help. Good luck, Robby
ak 11-05-2008 07:32 AM
cam swap
I have a set of morel roller lifters if needed to do this swap if you decide to go that route,this will save you some money,
jw454 11-06-2008 06:24 PM
The heads and comp ratio on the 300-330HP are not going to make anywhere near 500HP and unless you switch to a large oval port with 2.19-1.88 valves, good bowl blend, some port work, at least 9.5:1 comp ratio, a suitable camshaft and a performance exhaust, you'll never get even close.
searaycer 11-06-2008 06:29 PM
oops wrong thread
