-   -   Hydraulic steering (https://www.offshoreonly.com/forums/do-yourself-boating-budget/202885-hydraulic-steering.html)
bigboat28 02-08-2009 08:59 PM
Hydraulic steering
Anyone ever seen hydraulic steering with the pump under the dash?
DareDevil 02-08-2009 09:13 PM
Do u mean a PUMP or a pressure res. ????
They got Hydraulic steerings with no pump ass. only by pressure in a res. !!!!!!
A pump needs to be driven by a belt, unless u have the engine under the dash ,,,i don't think its going to work ??? LOL
VetteLT193 02-09-2009 08:01 AM
Manual hydraulic, the pump is in the helm... err, the pump is your arm strength.
There is also an add in to manual hydraulic that is electric powered. basically a booster like the power steering pump. that could go under the dash, but they are usually in the engine compartment.
bigboat28 02-09-2009 02:46 PM
Looking at a 28 foot boat neither of the motors have the pump on them ask the guy about it he said that it is under the dash, is that true?
DareDevil 02-09-2009 03:57 PM
Yes its a non suported power steering,,,,race boats used to have that,,,its a little hard to steer around the dock but ok on the go.
The helm is the pump!!!!!!!
bigboat28 02-09-2009 08:07 PM
The boat is a 82, when was that steering out? How good is it?
DareDevil 02-09-2009 08:55 PM
I don't recall ,when they start making them. But a friend of mine had the same steering in his raceboat up to untill he sold it in 2004.
And it worked great, the only thing is ,,,if not on plane its like having no power steering.
Ghostrider 02-10-2009 01:26 AM
Is that just a standard Hyd helm without a pump hooked up? Or is it a special re-geared / ratio'd pump like it would be for a manual car steering rack?
If it's just a regular hyd helm without a pump, how would you plumb the damn thing?
I would imagine it might be dangerous to turn in at speed as the water pressure on the drive might be stronger than the arm pressure holding the wheel so the drive might straighten on you. BUt if it's been used on race boats, you could assume it doesn't... can't you?
Now i'm curious to know how this is plumbed! Got any pics of a power pump-less setup anyone?
:party-smiley-004:
bigboat28 02-10-2009 09:10 AM
I am curious too.
DareDevil 02-10-2009 09:36 AM
:party-smiley-004:
It has a pressurized reservoir !!!!!! its easyer then cable steering but tuffer then pump assist steering .
It has a return line and everything like a new Hyd. steering just without the pump ,,therefor u got a press fill valve on the res. where u add air press with a compr. like on a tire and its good to go ,,,u may need to fill press once a year !!!
Raceboats had it back in the days ,,,so i don't think its going to be unsafe at all!!!!!!!!!!!!:ernaehrung004:
I bet u can add a pump aswell and get rit of the reservoir ??!!
KMP 02-10-2009 10:42 AM
I've got manual hydraulic on both of my boats.
The helm is basically a 2-way bi-directional fluid pump that uses a steering wheel instead of a motor. Resevoir is in the pump(helm). 2 hydraulic lines run to the back rams. If you have one ram easy. If you have 2 rams, the push on port side is tee's to the pull on the starboard side and vice versa.
There is no feedback from the drive. You can litterally jump waves sans' hands on wheel. (not recommended).
My 18' Donzi works great with it. The 24' boat works great till over 70; then the arms get a workout.
I would say very safe if hydraulic lines are good shape. The slighty stiffer and no feedback help from accidentally turning too quick.
Uncle Dave 02-10-2009 10:59 AM
Hyd steering
Many types exist.
Most I/o applications have a pump behind the wheel and use what amounts to a power steering pump driven off the engine to multiply the pressure to the rams. This works beautifully.
Should the engine die you can still steer, but its workout time.
It is a real pain in the A on older carbed blower rigs that dont want to idle after a hard run and tend to to die when jockying in and out of gear while docking.
Ive seen many Hynautic setups on outboat apps only use this one pump - and at docking speed you can really get a workout.
Uncle Dave
Ghostrider 02-10-2009 10:29 PM
The reason I'm interested is I'd love to do away with the p/s pump on my Stinger 222 and just run manual. It's plumbed with the full IMCO hyd helm all the way back to the single ram with in out and rtn lines for teh p/s pump at the moment. If I was to ditch the p/s pump, how would I plumb it? (what goes where?) I just figure if I don't need something, why have it? :drink:
KMP 02-11-2009 02:31 PM
3 Attachment(s)
Simple and less things to go wrong; I agree. The helm you have for power steering will not work well if you take out the pump. Take the belt off of your PS and see for yourself while on the trailer. You can change the helm unit to one that is set for manual (No Power Pump). Capalano has one, as well as a few others. You would need to make sure the volume is enough to cover 2 rams.
On my small Donzi I have a Hynautic helm, pushing a single IMCO ram. On the 24' boat with 2 rams I have a much larger helm similar to the Capilano in the picture. Kent
KMP 02-11-2009 02:40 PM
Miami 02-11-2009 09:58 PM
Scott, thats exactly the way your boat was originally set up, and we always raced it that way. I can assure you, it's not easier than cable. LOL !!
DareDevil 02-11-2009 11:10 PM
HAHA,,,i bet u where beat after each race and not from the chop either. LOL
Good thing it has full hydraulic now !!:drink:
Hope to see u soon ,, go to my website and check the race schedule so u know when i am close to u,,,,i sometimes even get lost in FL. LOL:party-smiley-004:
bigboat28 02-13-2009 06:20 PM
Daredevil how is the boating around Anna Marie Island? We usually go to Destin but are thinking of going to Anna in June. Is the water clear and blue like Destin with the white beaches? Are there a lot of small sand islands to go to that are secluded?
myscarab30 02-15-2009 02:34 PM
I have this same set up on my Ex.. Do a search on Hynautic Steering..There is a way to convert your manual steering to run off power steering pump..It sounds pretty easy
