-   -   sea strainer? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/203729-sea-strainer.html)
n20michael 02-23-2009 04:30 PM
sea strainer?
Hey Guys, I boat in fresh water and my Baja has a closed loop cooled 454 MPI in it, I am curious if a sea strainer will make any difference if using a closed look system in a fresh water environment?, the area I boat in is generally quite deep and "Clean", but, the docking area's are somewhat silty. Any input would be greatly appreciated!,
Thanks!
Michael
Jeff P31 02-23-2009 06:55 PM
Strainers will stop the big sh!t from getting to the pump and tearing it up. I found in my area that weeds are a big problem and the strainers work great. :ernaehrung004:
CPPerformance 02-23-2009 07:54 PM
Thanks!
Michael
There is no doubt that a sea strainer can and will help you in bad water conditions, consider it cheap insurance. Let us know if we can help as we have several different brands and styles to choose from including our most popular Hardin Marine "Swirl-Away" sea strainers that are known around the industry.
Thanks,
Brad
http://www.cpperformance.com/SearchR...?CategoryID=55
n20michael 02-23-2009 08:56 PM
I have noticed there are several different sizes, in a boat like mine with a single 454 and 24 ft long I assume as "small" one would be ideal?, I have also seen a few styles with a "3rd" input, that I assume is used for a "wash through" for the strainer, does anyone make a nice billet hose attachment for the "flush hose" or even a kit?, thanks again!
Jeff P31 02-24-2009 08:06 PM
1 Attachment(s)
Yes you can buy a fitting to hook up a garden hose to run the engine on or flush out the system. Just not sure who makes them. I'm sure one of the guy's on here can fix you up with all the parts you will need. Just remeber to put the strainer as low as you can in the boat with a valve on the in side and one on the flush out hose.
Jeff P31 02-24-2009 08:13 PM
And as you can see do not forget to order the stainless fittings because the brass one's look like SH!T !!!!!!!!!!!!!!! :ernaehrung004:
Elite Marine 02-25-2009 08:41 AM
We have the strainers, fittings and adapters!!
Email me your wish list. We can do better than our website prices!!
n20michael 02-26-2009 01:18 AM
Thanks for the help, and the pic made things ALOT clearer!, I think I found a new strainer from a fellow on the site, WOO HOO!!, talk about one stop shopping, I will check out your website "Elite", I am SURE there are piles of things I will be needing [wanting??] in the very near future, thanks again!
Michael
DareDevil 02-26-2009 08:24 AM
Hey Jeff,,,,put your fitting for the flush on the lower inlet,,,that way u flush out the strainer and it cleans itself.
If u got it on top and its glooged up a little u may not get any water to the pump on the hose. ?!:ernaehrung004:
