-   -   Gear Lube bottle/resevior (https://www.offshoreonly.com/forums/do-yourself-boating-budget/206438-gear-lube-bottle-resevior.html)
n20michael 04-07-2009 11:05 PM
Hey Guys
My motor [454EFI] has a factory gear lube container that sits up on top of the Left hand side of the motor [towards the bow] it has 2 wires that come out of it that limit RPM if the oil level gets too low, the damn thing leaks around the "nut" on the bottom of the plastic resevior, I have epoxied up a few times, but, eventually starts to leak again, I am trying to decide if I should replace it with a new one, or maybe see if anyone makes a cool aftermarket tank I could use?, I dont mind buying a new OEM one, but, if its gonna start leaking in a summer or two, I might as well get something else. Thanks for any input, and hope everyone has a Great Easter!
mr.boat 04-08-2009 12:19 AM
try lyall turbosonic. i think lou makes more than just caps these days. also check dana marine products, eddies marine, rex marine and cp performance. over.
Griff 04-08-2009 01:28 AM
He is talking about the bottom leaking. It happens all the time with them. The merc ones are relatively cheap compared to aftermarket ones. A lot of them do leak after a about 5 years. The wires are to set off the audible alarm if the lube goes low.
DareDevil 04-08-2009 11:58 AM
Take it out and take the nut off,,,,then seal it with a real good oil resistend sealer and be done !!!!
Griff 04-08-2009 01:44 PM
The ones that I have had leaked where the wires go through the nut and are sealed.
Nordicflame 04-08-2009 03:19 PM
I have two basically new take offs that you could have for $75 shipped to you.
That should be ten years worth :drink:
Let me know...
Dave
n20michael 04-10-2009 09:33 PM
I think I will try and seal it up, doesn't look as bad as I thought, will let you know, if it doesn't work [knowing MY luck..............] I will let you know, Thanks Nordic!
I'CE 04-12-2009 12:30 AM
tanks
Let me know...
Dave
Dave, round or square? also Teague sells some nice set ups.
n20michael 04-12-2009 12:59 PM
Thanks!, will have a look online at the Teague stuff!
Nordicflame 04-13-2009 07:14 AM
Square...
