Head Question!!
Old 04-18-2009 | 08:12 PM
Default Head Question!!
Hi i'm building a 496 stroker and have found these heads for a good price do you think they will work . they are edelbrock 308cc heads with 119cc combustion chambers they are cut for 2.250/1.888 valves. the part # 15100010. If the 308cc are too small can you suggest any other heads. thanks for the help.
24sleekcraft is offline
Old 04-19-2009 | 05:08 PM
I have a 489 stroker. I use Large Oval 820's with 2.19/1.88 valves. Are these Large Ovals or Rectangular? Unless you have a 540 or run real high RPMs the Bigger ports are not nessesary. If you run to large of a head for you engine you will actually hurt your low an mid range. If you are going to upgrade your cam call RMBuilder before you do anything. He will give you good advice.
jeffswav is offline
Old 04-19-2009 | 06:42 PM
Those should work pretty well for a 496.
Griff is offline
Old 04-20-2009 | 09:59 AM
I run large ovals on my 496 but I had them install 2.25/1.88 valves with 11/32 stems in mine and mine are cast and run great
Sweet Nmocean is offline
