-   -   Water pressure on 496HO's (https://www.offshoreonly.com/forums/do-yourself-boating-budget/207742-water-pressure-496hos.html)
Back4More 04-27-2009 07:31 PM
A friend is doing a dash upgrade and wants to add Water PSI gauges to his 496HO's.
Where would he tap into the raw water system to get a good reading?
Also what is a normal psi reading for the 496 at WOT?
LAKESIDE RESTORATIONS 04-28-2009 09:46 AM
On the rear of the engine there is a sensor in the PS cooler. You can get a brass T & tap in there. Jamie / Lakeside
Back4More 04-28-2009 12:42 PM
Thanks man!
BTW, cool 33' Apache!
monstaaa 05-02-2009 10:03 AM
to see 35-40 psi @W.O.T is not out of norm if yur runnin round80.
RaggedEdge 05-02-2009 12:06 PM
What would you consider to be normal on the 525's at 90 mph?
CheckedOut 05-04-2009 07:25 PM
You should see about 25-30psi i think with that setup. You should be good with 35psi guages. I got the bigger ones and wish i hadn't.
