Looking for a Prop Puller in Boca
anybody know where i can borrow / find a prop puller in boca or near by>?
thanks Dave |
What kind of prop?
Its for the fishing boat - 19Pitch 3 blade SS Standard Yamaha
thanks . |
Outboard? Don't you just need a socket? I have all sizes and a 18" rachet if that's what you need?
Exactly, what Ray just posted, Ray and I are both in West Boca also. The Yamaha should be the same as a merc, 1-1/16 nut, and a tab washer. Bend the tabs out of the way, wedge a 2x4 between the prop blade and the cavitation plate, and turn the nut counterclockwise. If you need any help, we are local.
= the prop was put on dry and run in salt water for 5months - ive been beating the s*** out of it for hours..
now im being told to grind / cut / the old prop off. any ideas? |
I have one in my garage but its 250 miles from you. sorry
Originally Posted by BocaVice
(Post 2854939)
now im being told to grind / cut / the old prop off. any ideas? Don't cut it !!!!!:eek: |
"PB-Blaster" blows away WD40 10 fold. Try spraying it for a day or two and it may surprise you.
(Post 2854939)
now im being told to grind / cut / the old prop off. any ideas? now that makes sense, I dont have a puller big enough for that, but I bet if you were to take it to a marine service place they could get it off, you dont want to cut it, unless it is aluminum, steel would just take too long. There are a few places around here that I could reccomend, and they are both on this board. BAM Marine in Pompano(Marc), or Doller Offshore(Mindi, Dana, or Art) in Hollywood. Both also sell replacement props if you need one. Rick |
| All times are GMT -5. The time now is 01:00 AM. |
