TRS to Bravo
Is the hole cut out in the transom smaller for the TRS drive than a Bravo cut out?
Transom would have to be glassed, recut, and the motor moved back becasue there would be no transmission.
Konrad conversion is a better solution or find a back up TRS drive. TRS will handle 550HP if set up correctly |
Originally Posted by cigrocket
(Post 2859336)
Konrad conversion is a better solution or find a back up TRS drive. TRS will handle 550HP if set up correctly I think its more like 650 -700 HP !!? Hey,,did u get one now ? |
Stellings Marine has/had a extension box to go from TRS to Bravo.
Originally Posted by JasonSmith
(Post 2859547)
u could use a Bravo box ( stellings ) and weld a plateon it with the bolt patern for TRS.
Since they are for drive shaft appl. it will work !!!:ernaehrung004: |
I would think that putting a box on would not be that great of an idea. TRS drives are mostly buried in the basement when it comes to mounting height.
The Konrad is really a better solution. It doesn't mean it is the only solution. |
| All times are GMT -5. The time now is 08:16 AM. |
