Bravo I Drive won't go DOWN?
One of my drives will not go DOWN.
Doesn't sound like the motor is operating, both (I have two drives 38KV Scarab) drives go up with the switches and with the trailer switch, just one will not go down. where to start????? |
Down solenoid on that side is either bad or power is not getting to it for some reason.Is it clicking when you hit the switch?If it is try jumping a wire across it to see if the motor runs down.If it does then the solenoid is bad
EASY FIX!
Was the cannon plug connector, must have bumped it when doing the Oil change! Everything works great again-thanks for playing now back to our normal program....... |
thanks Picklenjim! Went back out while you were responding and checked the connectors--talk about an easy fix!
I was about to call Tres! Saved him the trip and some gas money for myself. |
| All times are GMT -5. The time now is 04:25 PM. |
