-   -   switchable muffler experience?? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/210783-switchable-muffler-experience.html)
ZXXX Donzi 07-09-2009 06:23 PM
Originally Posted by cloudmaster_321 (Post 2900610)
I was all set to get the Teague system as well until i heard you can't run full throttle with the mufflers in the quiet selection. Here in Madison, WI, our water patrol will actually board your boat, and make you run full throttle through the traps making sure your full throttle when they test for db. So if the systems have limitations in RPM's due to design, then i can't use them. I'm settling with IMCO Gatlin mufflers now unfortunately...........
I would LOVE to see the look on our water patrol riding around with me at 100mph in my little 26 foot Donzi. Or better yet, I can jack the nose up at 85 and hit a good side wake to show them my nasty chine walk trick.
extra300 07-09-2009 09:06 PM
Originally Posted by jeffkopec (Post 2894659)
I have a 502 around 600 horse with plenty of snap to it. I am using the teague switchable tips and they work great with my application. I have actually passed with 86.7 db with the mufflers closed. When they are open it is still extremely loud as I am running 4.5" exhaust. I don't know about the system you are looking at, but I can sure recommend the teague system.
Where can I take a look at these, and about how much do they cost?
thanks
paradigm shift 07-09-2009 10:22 PM
Try this. I run the teagues also but they do not recommend wot use. I use turn downs also which do help on plane and is quite as a bay liner at idle.
http://teaguecustommarine.com//store...th=198_514_515
