Stiff linkage, Quicksilver Throttle
Shifting is somewhat stiff in and out of gear which is ok, but the throttle movement itself is pretty stiff. Is there a friction adjustment anywhere to fix this?
Cable looks to be knew, binding feels like it's coming from the shift housing. Thanks- Going to a 496 if it makes a diff. http://i47.photobucket.com/albums/f1...5/IMG_0069.jpg http://i47.photobucket.com/albums/f1...5/IMG_0070.jpg |
Start by disconnecting the shift and throttle cables from the engine. Check control box for stiffnes. If still stiff, replace the control box. Had same problem with Merc Commander controls . It had twin engine set up and both boxes went bad.
| All times are GMT -5. The time now is 07:49 PM. |
