496 ho promblem
I have a lack of water exiting left side exhaust, already replaced impellar and backflushed system.Seems to have good water flow to bottom of manifold
I guess I might have the same question. I've had mine now for about 3 seasons and have noticed from day one when hooked up to the hose it always takes longer for the water to exit the left side and always less coming out than the right. Even setting in the water and firing it up same thing. Never had a problem never been stranded and 150 plus hours latter still does it. Never had the nerve to check it while on plane, I would imagine at the higher rpms it would even out. Hope to see other responses as well
Check your check ball units at the bottom of the manifold inlet, if they are stuck open, all your leftside water will not go out the exhaust manifold.
Best Regards, Ray @ Raylar |
I have same issue but assumed it was due to my pro charger somehow. I always end up with more black soot on left and fiqured it was related to less water on that side to wash it out when running. I quess I rather to rich than lean. I tried asking around to see if anyone else ever had the concern but never had any answers. So is it something that should be addressed or leave well enough alone?
Originally Posted by Raylar
(Post 2957624)
Originally Posted by specialk
(Post 2957694)
Fasthawk6:
No, it will not trip a guardian alarm unless the exhaust manifolds themselves get over 160 degrees, if you keep running the engines with the water to the manifolds and elbows reduced eventually they will see an overtemp, then the water temp sensor for the exhaust manifold will sense the overtemp and sound the alarm and put the engine in a guardian mode. A scan tool or software can allow you to monitor the temps and guardina events. Best Regards, Ray @ Raylar |
(Post 2958602)
Fasthawk6:
yes, i just had the same problem. The quick connect came off, and engine was sucking air and manifold heated up, alarm went off. I found the check ball and put it back together with a hose clamp to hold the thing on. What a crappy design, a motor with all that power and coolant flow and this is what they come up with.
Originally Posted by sunman496mag
(Post 2961408)
w hen my engines were stock Teague drove my boat and said they heat soak which ment the boat was faster before coolant got hot ,what I have learned from the drive to the pump good water pressure not enough back pressure the water went through to fast I put restricters in the hoses on the exhaust no steam runs ALOT cooler look at the restricter on 525s exhaust in the little c hose on riser
33
crayola,
trying to reach you but your p.m box is full |
My Baja with 496 Mag Ho had less water comming out of the left exhaust from from the time it was brand new, But only when using the fresh water flush.... when it was in the water the flow out the exhaust was even at idle...
Originally Posted by dlange
(Post 2967719)
crayola,
496 less raw water from left side
Im having the same issue with less water flow from left side qand more steam. Has anyone fixed this or should it be left alone. I have noticed do to water flow left side manifold does run hotter then right. I have checked the ball valves at bottom of rail and they are fine. Should i worry about this or leave it alone.
:lolhit: |
| All times are GMT -5. The time now is 11:28 PM. |
