-   -   Help! 98 502 efi loud clanking from engine (https://www.offshoreonly.com/forums/do-yourself-boating-budget/217715-help-98-502-efi-loud-clanking-engine.html)
JimKav 09-29-2009 07:38 AM
Fomula 353 w/stock 502. engine cut out in east harbor. Started back up and heard loud clanking from what seemed the top (end loud knocking). Shut it right down came in on starboard only. what should I look for when I pull the valve cover? anything problematic w/this engine (98 w/300hrs). Any help would be appriciated.
dennis r 09-29-2009 08:50 AM
I would bet the exhaust seat fell out of your head.
batboat 09-29-2009 08:51 AM
Bad valve seat I
pretty sure
JimKav 09-29-2009 09:19 AM
would that require new piston? or just top end re-worked?
PatriYacht 09-29-2009 10:12 AM
When pulling valve covers, look for a loose rocker arm, broken spring or bent broken pushrod. If they're all ok, you have to dig deeper.
dennis r 09-29-2009 01:15 PM
You need to do a total rebuild when you pull off your valve covers take off the rocker arms and look for a spring that is taller then the rest.
rlong 09-29-2009 02:53 PM
same thing
Good luck mine did same thing 95 502 490hrs pulled the motor for overhaul and it had a spun crank and the block is scrap so now will a new 540. Sure hope it is in your top end you can see with a compression check which cylinder s bad.
mike tkach 09-30-2009 01:32 AM
this happens a lot with the mercury 502 cylinder heads,it usually destroys the head,and the block will need to be bored,invovles a total rebuild.:party-smiley-004:
