-   -   Need a reverse rotation cam (https://www.offshoreonly.com/forums/do-yourself-boating-budget/219396-need-reverse-rotation-cam.html)
f_inscreenname 11-01-2009 12:10 PM
I would have put this in the wanted section but for some reason i cant post there.
I'm looking for a reverse rotation cam for a 454. The cam that uses a gear instead of a chain. I'm looking for something besides stock (I have one already). They are so limited that I will work with what ever I find.
KNOT-RIGHT 11-01-2009 12:38 PM
I have a crane 741 reverse rotation cam (hydraulic roller) with dist gear. It has approx 100 hours on it.
This uses a chain and stock dist.
The firing order is reversed
I removed it when I went to SSM6,s.
Dont know if you could use this.
Gerry
508-399-6440
ezstriper 11-01-2009 04:22 PM
if you use the cam that used the chain you MUST use a specially made EST dist or it will eat distributors in no time at all....went thru 4 before we figured it out....Rob
KNOT-RIGHT 11-01-2009 04:54 PM
Thats why I kept the gear with the cam;)
f_inscreenname 11-01-2009 07:31 PM
I thank you all but I am trying to use what i have because i have to build a normal rotation motor the same exact way so roller is out. Something that will work with a cam gear.Or the basic Mercruiser reverse rotation 454.
Griff 11-01-2009 08:35 PM
Unless you have them custom groud, I'm 99.9% sure you'll never find anything.
KAAMA 11-01-2009 08:47 PM
RMBuilder/Bob Madara of Marine Kinetics in N.Y. can get you just about any cam you want including a reverse rotation cam such as you're inquiring about. 585-654-8583
f_inscreenname 11-01-2009 09:31 PM
Thanks.
I was making that call tomorrow. Just wanted to check to see if anyone had something sitting in the garage.
ezstriper 11-02-2009 05:57 AM
well as all reverse rotation engines were inboard boats, finding a H/P version not likely laying around as it would have had to been a custom grind...Bob's the man you need
f_inscreenname 11-02-2009 10:33 AM
I figured as much but had to ask. Just didn't want someone coming out with, "I have one of those i would have gave you" after the fact. Anyone have any idea what Bob would charge for something like what I need?
Panther 11-02-2009 11:21 AM
Could be wrong but I thought the cam was the same as std. rotation, the difference being the gear turns it the opposite way? Cam actually turns the same direction as standard but the rotating assembly turns reverse and has a reverse starter etc.
larry smith 34 11-02-2009 11:41 AM
cams
call me i have a pair with gears 301 529 6371
f_inscreenname 11-02-2009 01:44 PM
It does turn the same way but the lobes on the shaft are different to accommodate for the new firing order.
Larry, I can give you a call in a couple hours when I get home from work.
What you have? any specs?
Panther 11-02-2009 02:08 PM
You said you're using the gear instead of the chain so I'm pretty sure you can use a standard camshaft but would just need to change the firing order on the distributor.
Try a search on here, there have been many posts about it.
http://www.offshoreonly.com/forums/g...502-motor.html
f_inscreenname 11-02-2009 02:35 PM
You see, without getting to deep in this, the cam spins the normal way. The crank is the only thing that spins in reverse. With the crank spinning backward the cam events are set up to happen in order but unless the crank journals actually mirrored a normal crank they come up in the wrong order. If I was to use a normal cam and just try to spin it backwards it would suck up exhaust and blow gas out the carb. You also have to take into account that a cam like this works off a gear and gear slips over the cam shaft and is held in place with a key. Most cams do not come with the little core extension for the gear to ride on.
Panther 11-02-2009 02:55 PM
See below;
Originally Posted by Young Performance (Post 2876962)
If it uses a gear drive, then the cam and distributor spin in the standard left hand direction. The only thing that spins backwards is the crank. You will need a timing set and a starter. The cam and distributor are the same as the left hand engine.
Eddie
f_inscreenname 11-02-2009 04:36 PM
Originally Posted by Panther (Post 2984053)
See below;
Sorry but that's not true. I have two cams sitting on a work bench now. They are nothing alike and they are both from Merc 454 motors. Just one is a right and the other is a left.
Just think of this. If you run a cam normally it is by design to open and close the intake and the exhaust valves at a certain time. Like when it opens the intake just as the piston starts it down stroke. Now if you spin the crank backwards you may get #1 to work but then the cam is designed to "set up" #8 not #2 (it's next in line on a reverse rotation motor). The lobes on the cam have to be just a little different to set up the next numbers in the firing order.
a to z marine 11-02-2009 06:46 PM
That is correct the cams are different r/h uses a gear to gear and the cam is grind is different for a reverse fire order you can not use a l/h in a r/h motor you can look part #up on www.mercruiserparts.com
KNOT-RIGHT 11-02-2009 07:29 PM
There were to ways this is accomplished.
1) Gear drive which keeps the cam rotation standard.( Crank
rotates opposite).
2)Chain drive which rotates cam aswell
as the crank opposite. The gear at the end of the cam
is machined to mate with a special distributer gear.
This in turn (no pun intended) spins the oilpump the
proper way.
LH Cam is a different grind then RH.
Hope this helps
KR
f_inscreenname 11-12-2009 03:01 PM
Bob is no help. :(
fastdonzi 11-17-2009 07:02 PM
Originally Posted by f_inscreenname (Post 2989819)
Bob is no help. :(
Why Not????? Hows your V-drive coming????
MarineShopInc 11-17-2009 10:05 PM
I have, in stock, the cam, gears, and also the rear main seal. the seal is different for a rh rotation. Jim 954.587.1910
Racerx427 05-14-2023 04:10 PM
I have a comp reverse rotation roller cam pn 11-999-3 lift intake.623 exhaust.651.
DrFeelgood 05-14-2023 04:53 PM
ya think he's still searching for one, 14 years later?
