Cleaning the interior....
Old 01-03-2010 | 11:32 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
We have been doing some deep cleaning last night on the boat interior cushions and tried several items on a couple trouble spots, as I was out of the Eraser: 409, Bleach White tire cleaner and 3M'S vinyl cleaner. None of those items worked. The Erasor took it off with no effort, plus now the vinyl is whitey white. I always follow up afterwards with a soft brush and 3Ms cleaner/conditioner to get in to the threads and grain, then go over it all with the 303 heavily a couple times and let it soak in. As a rule, I'll just use the Eraser on troublesome spots or for when doing a deep cleaning once a yr, not every day use.
US1 Fountain is offline
Old 01-03-2010 | 09:29 PM
the best thing I have found is that magic eraser. it can clean anything, or at least damn close to. if that does not work, spray some roll off and let that sit then blast it with the magic eraser. between those two things we clean almost everything on a 145 footer and all the tenders and toys. and we have three 10 ft dock boxes full of cleaning supplies and those two things get used the most by far, and I usually stock about 100 magic erasers and a few gallons of roll off.
Perlmudder is offline
Old 01-04-2010 | 03:21 PM
Default Cleaning
Yep agree with the "Majic Eraser" I spray vynal with Marine Spray Nine let soak then rub with the majic eraser, wash off then hit vynal with a conditioner. Bleach white, and other cleaners are good on the vynal often they will eat up the threads.
pocketchange22 is offline
Old 01-04-2010 | 10:18 PM
Default Aa
Leverage vinyl cleaner with Magic Eraser is awesome, if you have something where that isn't working, I use Goo-Gone, or any other "citrus" cleaner. As stated use a conditioner post cleaning.
bert4332 is offline
Old 01-05-2010 | 06:09 PM
PQ26's Avatar
Originally Posted by antknee
Ok I just received my bottles of Leverage vinyl cleaner and got started on the interior. Seems to be working great on most of the side panels but the seats are a different story. The previous owner left most of the seats out in the weather for a while and eventually put all the seats except the driver seat in storage so the driver seat is showing the most grim and dirty water spots on it. Anyone have any suggestions or tips/tricks of the trade to get the tough deep dirt and grim out?
SD-20 by Spartan Chemical - works amazingly on white vinyl. Spray it on, wait 3 seconds and then use a brush to clean and follow up by wiping it off with a clean rag or towel. Not sure if you can by it retail. I get is from an industrial distributor. Our marina uses it to detail boats. The service guy at PowerQuest Boats recommended it to me 5 years ago.
PQ26
PQ26 is offline
Old 01-05-2010 | 06:37 PM
Break out the big chemicals. If you have stain issues, use Acetone. You can get it at Home Depot. Get a rag completely wet then wipe an entire panel/cushion. Then use 303 to re-seal it. It works very well but its rough on your hands. It removes everything - if this doesnt work, forget it, you cant fix it.
Keith Atlanta is offline
Old 01-08-2010 | 07:05 PM
grease lighting and magic eraser then apply 303. always eariser if you pull the seats. that way you can get the entire seat clean and protected.
capt2130 is offline
Old 01-09-2010 | 01:41 AM
Acetone is a last resort. It will actually melt off the outer layer of finish on the vinyl. It will also make the vinyl get dirtier easier because it removes the finish.
Griff is offline
Old 01-09-2010 | 12:37 PM
Ginger or Mary Ann?
Yeah, I've seen the grain texture melted before from acetone use.
Old 01-10-2010 | 12:25 AM
There was a product I used to use called Bypass (I think I'm spelling it correctly) that worked GREAT. You had to actually follow the directions and let it sit for 45 seconds to one minute, but it was an awesome product when paired with a mild or even a soft scrub brush.
It actaully sounds a lot like ROTAX454's product, but it's only about $15.00 a gallon.
wjb21ndtown is offline
