-   -   Holley difference? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/222423-holley-difference.html)
Sunshadow 01-08-2010 01:31 PM
Holley difference?
What's the difference between a street Holley and a marine Holley besides the j tubes and vacuum ports?
Flamingo 42 01-08-2010 01:56 PM
I belive everything is redisigned ( grooved and bushed throttle shaft, J-vents ect. ) so fuel cant leak into the engine compartment
brians fever 01-08-2010 02:09 PM
shouldnt you be working ???:lolhit::evilb:
getrdunn 01-08-2010 06:34 PM
I have researched this much myself and the only real difference I could find was the j-tubes. When you look at all the spec on both I can't ever seem to find any difference. I do know the j-tubes can be easily converted to a street carb. As you know if the Coast Guard sees the straight tubes you will be ticketed more than likely. I could easily be missing something here however I have rebuilt several of each and yet to find any difference in the internal components. I have also run holley street carbs on marine applications and noticed absolutely no diff. Some models use a different float system for marine carbs also perhaps due to the rougher environments. Hope this helps. Basically the j-tubes just keep any excess fuel back into the carb.
rdoactive 01-09-2010 03:07 PM
"USCG approved" and holleys already have a habit of causing fires from leaks in the pump diaphram.
Dont even think of using or coverting a car carb, you never know what the insurance Co might do if something bad happens.
Sunshadow 01-09-2010 03:59 PM
Ok how about opinions between Holley and Edlebrock carbs?
fireboatpilot 01-09-2010 05:37 PM
Limited to 750 cfm by Eldelbrock.
[email protected] 01-09-2010 05:38 PM
i love edlebrock carb they dont seem as tempermental as a holly. on the other hand holly is designed for straight hall ass and in my opinion would be the best for a boat considerin the application and constant high rpms, what i sayin is if you have a race car put a holly on it, if you have a street strip cruiser put an edlebrock on it. and by the way i have auto mtive holly 750s in my boat and love them.
rdoactive 01-10-2010 07:46 AM
What's the application?
Keep in mind the Edwlbrock = Carter AFB = Weber used by Merc on their last carbed motors up to the 410hp, 502.
You can find used Webers for under $100 easily.
ezstriper 01-10-2010 08:32 AM
J-tubes and jetted up slightly for the most part....as far as the edelbrocks, as other said good std cruising carbs, use a pair of 600's on my 454's, they never see over 3800, and they work great, but for real performance holleys are much better...
Sunshadow 01-10-2010 10:04 AM
1 Attachment(s)
I'm building a 383 for my 23' wellcraft I tend to take it easy on my stuff, I like to run without breaking if I can. I know lots of people with big fast boats so I'm tempted to keep up every now and then.
rdoactive 01-10-2010 10:45 AM
So you're certainly under 400hp......
If it's a budget issue and your not running too big of a cam or after the last 20hp at 5500rpm, go with the Weber off a Merc BBC (under $100). It will probably be jetted ok as is. The only thing you might have to fab/modify is an inverted flare fuel line. Although one from a Merc 260 SBC motor might work.
A Merc Qjet from a 330/365hp Merc would work for that too and are generally better at starting and idle.
Sunshadow 01-10-2010 12:20 PM
I hope to be right at or just under 400hp. I'm running a fairly high compression ratio for a marine engine just over 10 to 1 and a cam that's going to want as much dry exhaust as I can give it.
rdoactive 01-10-2010 12:44 PM
Well Merc used the Webers on their 410hp 502s, so they'll flow in that range, and Qjets were used up to 370hp motors. Both are about 750cfm. So like I said, you might gain a few hp by going to a 800+ cfm Holley if you honestly think you'll be pushing 400hp, not sure if that would translate into even 1 mph more.
But since this is the "Budget" section, I'm going to guess that used marine Webers will be a lot cheaper and easier to find than marine Holleys.
ACrooks69 01-16-2010 07:20 PM
What cam are you running and what heads are on there? I ran a RPM intake with a JET mod'd merc QJet and pull 436 Hp on the dyno. If you want to run a Qjet that is setup well for the 383 power curve in a boat let me know, I want to get rid of it. I have a pro systems carb on a single plane intake now, pulling just under 500hp.
endeavour32 01-23-2010 03:16 PM
The Weber Merc Carb 750 CFM is good to 550 hp. I believe he rates the 750 qjet good to 475 hp. The 750 Vac Secondary Holley is good from 400-550 and the 800 vac for 500+. This is out of Dennis Moores book "BB Marine Performance".
I'm going to be running a 750 weber on my 439 bbc. IMO a 750 on a 383 is going to be too big. 650 would be a good size for that motor.
FIXX 01-23-2010 04:43 PM
I have a 750cfm holley on my 355,runs sweet! :)
here you be the judge
http://www.youtube.com/watch?v=I78vehnSmF8
bajabob 01-23-2010 05:51 PM
nice !you are set up real good .i would copy your set up in a heart beat .how fast do you go???
FIXX 01-23-2010 06:34 PM
fixx
in that vid lower 70's,,the boat throws you around a bit and its hard to read the gps at times..i dont have a recall on mine
mind you all the power is going through a volvo 280 drive..
jtmarten 01-23-2010 08:14 PM
Be real simple to email Holley for an answer.
http://www.holley.com/TechService/TechRequest.asp
Strip Poker 388 02-24-2010 10:26 PM
put a Hp Holley or a 4779 on it,Garry Williams here sell the j tubes,run a flame arrestor ,only prob is if the needle and seat sticks,ck the prices of the street Barry Grants, might be real close to Holley
fireboatpilot 02-26-2010 04:17 PM
Where do I find this Garry Williams? I would like to pick up several sets of the J tubes?
picklenjim 02-26-2010 05:23 PM
Here's a place you can get the J-tubes. I got a set and converted a street 850 DP and it works great. Part number 85-453. $7.59 each. Besides the J-tubes Holley advertises that their marine carbs have the fuel metering system calibrated for a boats unique engine load.
http://www.carburetion.com/parts.htm
Strip Poker 388 02-26-2010 11:06 PM
601-939-5861. located in Florence, Ms. tell him Rob Stringer sent ya.
He's dry and short.Pat Musi uses him a good bit,
ezstriper 02-27-2010 10:41 AM
I would contact patrick at pro systems
NOPUN 03-01-2010 12:17 PM
Gary Williams = Best carb guy ever!!!
Run one of his carbs on my drag car , never had to touch it .
Tell him what you have and what your doing with it and he will custom make the perfect set up for your app.
ACrooks69 03-03-2010 09:52 AM
I second Pro Systems. That guy knows how to set up a carb.
