Idle surge?
My Baja with a 454EFI has a "surge" at idle, it only surges a couple of hundred RPM's but, its kind of annoying, last spring I had the boat checked over and the mechanic said he "cleaned" some Idle valve or Idle control or something like that [sorry, I cant remember the exact name] but, he also told me it would need to be replaced in the next little while, anyone know what he was talking about? LOL, I would like to get one and swap it out before I splash the boat, Thanks for any input!
Michael |
1. Throttle cable to tight - no slack
2. Timing is wrong |
try cleaning the backside of the throttle plate,,,its easy and should help,,,let us know
Throttle cable and timing are fine. How do I go about cleaning "backside" of throttle Plate? I had the top end of the motor rebuilt last year, runs great other than the slight surge at idle. Thanks!
Michael |
Fixx
Originally Posted by n20michael
(Post 3091476)
Michael |
Idle surge
yea mine does that too.. both engines??? I have contacted the cam manufacture. :evilb::evilb:
(Post 3091436)
Michael |
IAC Valve and Idle control motor BOTH sound very familiar, are they easy/cheap to fix? or clean? I have no idea where they are, so, if you can Email/post/PM me and let me know where they are and where to buy them I would GREATLY appreciate it!
Actually when the boat first starts the idle stays "stable", but, if I give it a "shot of gas" [in neutral] the idle starts to surge, I am not sure if thats relevant or not? but, figured it coudln't hurt to let everyone know, like I said, other than that it seems to run great! Thanks! Michael |
(Post 3091991)
Thanks! Michael The IAC motor should be on top of the motor either behind or in front of the throttle body and the TPS sensor will be on one side of the throttle body on one end of the shaft that goes straight through the throttle body. The IAC motors will run you approx $100 and you will have to get these from a marina that sells merc parts and the TPS sensors are approx$30 or so from auto zone if I remember right. Either one will only take you approx 5-10 minutes to replace. I had the same issues with both of my 350 mags last year and said screw it and replaced them both on both motors versus trying to clean them again. |
My boat has the "454EFI" motor, which is similiar to the 454/502 Mag, the plenum is "flat" and the air cleaner faces the right side of the boat, do I need to remove the top of the plenum to get to either one of these parts?
Thanks! Michael |
| All times are GMT -5. The time now is 08:50 AM. |
