454 with trs
ive have dropped a valve in #3 cylinder. i need to pull my engine, i have an 454 with br transmission. would i need to seperate at the bell housing, or at the transmission to pull the engine, whats quickest or easiest way to do this? any info would be greatful
Is there another reason your pulling the motor ? The heads can be taken off with it still in the boat.
Originally Posted by [email protected]
(Post 3110914)
Did the valve take out a piston? |
thanks much, yes the valve decentagreted my piston beat to hell and back cylinder wall cracked, i already have another block just need to get this one out, thanks again for the help!
Lots easier to pull with the transmission attached. You'll thank me later....
Originally Posted by goldeneyee
(Post 3110978)
[QUOTE=Rookie;3110962] Don't ask me how I know.
:grinser010: Got that t-shirt a long time ago also.. |
Take the drive off, unbolt enginemounts and take her out !!!!!!!
Same way it will go back in and then stick the drive back on !!!!!!!!!!! Total time..maybe 1 hour !!!!! |
(Post 3110978)
Just did mine take out with trans took me about 2.5 hours at my shop with air tools and a chain fall. I bagged all my bolts and marked each one so assembly is easy. Im not sure about an Hour not sure how thats possable even with air tools and chaion fall.
-Mike |
Originally Posted by DareDevil
(Post 3111028)
Easiest way is to pull the drives, two trans mount bolts, four bolts on the pillowblock motor mounts, disconect hoses, electrical, and yank em out ! if ya do not mess with the motor mounts, and stack the trans to the gimble springs , she'll drop back in easy, drive should slip in easy, or get out the alignment tools !.. I have had my Scarabs motors/trans out 11 times in 3 years.. :lolhit:been there done it.:eek:.you want to know the wrenches and socket sizes you need ..I have them memorized! :drink:
hey guys thanks for all the info. now im a little new at the whole pullin the motor but takin all my stering bars and mounting brackett off the out drive took me about 15 min. but pullin the motor and tranny and makin sure what to take off so i have enough room to hook up all my oil coolers and rear cradell motor mount took me about 3hours but it was very easy having a boom truck not to mention i waited an hour for it to show up. now however i am dreading putting the damn thing back in the boat so if you have any pointers on what i should go ahead and put back on the motor before i drop it back in because i no its gonne take me a lot longer to hook every thing back up THANK AGAIN EVERYBODY!
pay close attention to the spring and washer between the trans and inner transom plate:evilb:
Remove trans?? = trans cooler?? drain fluid? just something else to disconnect if you have one - shift linkage? - remove drive? - heavy sum be-ahh-ch.... Why create more work?
You would need to figure out some way to support the front of the transmission if you want to do it like that. You will have to slide the engine forward to disengage it from the transmission. Putting it back in will be even harder. I guess it can be done but it just isn't the usual way of doing it.
3 Attachment(s)
Originally Posted by picklenjim
(Post 3123231)
| All times are GMT -5. The time now is 09:10 AM. |
