there was a post about a product that you just spray on and then hose off and worked real well .....I have looked but cant find the thread ......m
Originally Posted by BenPerfected
(Post 3140611)
We decided to test first. We used the Brillo type steel wool pad on the inside of of a main beam. Looked perfect....twice wet in fresh water and right back to where we started. For us, it was the same as trying to polish a lower case on an outdrive...won't last.
It is also enough work to consider hiring $10 hr day laborers. :drink: offthefront- if you could get me the name of that spray, that'd be awesome! Thank you |
Originally Posted by offthefront
(Post 3145149)
Go to any semi truck wash, usually around the big truck stops. They use a type of acid on the semi truck fuel tanks, wheels, etc. Spray on, rinse off. Will turn the aluminum bright, but not shiny polished. Its the only thing that makes my aluminum wheels on my dump truck look decent, especially if theyre pitted like mine are.
we get it for sleds
"sled-brite" or "aluma-brite" in it's more generic packaging |
Originally Posted by Rippem
(Post 3146644)
we get it for sleds
tip: spray from the bottom up or you'll get white streaks when it runs
| All times are GMT -5. The time now is 12:23 PM. |
