| Den P |
06-29-2010 09:06 PM |
Chug, and not the fun kind...
Ok...Working on the Rogue project...454, Bravo 1. There is a major chug when idling, and also at increased rpms...I do NOT think it's the engine. The motor sounds good, and I can idle it right down, and don't hear a miss. However, when this "chug" happens, and it's not timed like a missing cylinder, it's severe enough to shake the engine. Watching the gauges, and they move when it chugs, but I think it's from the shaking. There's also a faint metallic sound, like something rattling around, but it's not like an engine rattle. Once again, I don't think it's an engine miss...Standing behind the boat with the exhaust coming thru hull, it sounds like it's not missing a beat...You can hear the chug the along with a good idle. This happened without the drive on it as well. The gimbal bearing felt smooth and tight before I put the drive on. It will shift into fwd and reverse easily, with no change in the chug. Same with moving the drive up and down...Thanks...Den
