| pinkpanther |
07-02-2010 07:09 PM |
Oil filter bypass valve on Gen VI
So after reading through all the forums I need to make sure I understand this completly since my motor is fresh from builder. I am using a remote oil filer and I pulled the 2 bypass valves today and the one on the side says its a 35lb and the one in the middle under the oil filter nipple was a 45lb. So I should leave the center one out and use a 35lb on the side and thats it???? Motor has been out for almost a year now and still figureing out the wiring and hoses. The oil out should go to the remote filter then to the oil cooler? Is this correct?
