Trim Tab Question...
is it possible for a set of trim tabs to interfere with bow lift even if they are in the fully retracted position?? I have seen boats identical to mine in make/model/power plant get some really good bow lift but mine wont come up like it should, the only difference is mine has a big set of tabs on it and the others dont. I also think the the lack of lift is hampering my top speed due to more drag, any feedback would be appreciated.
1987 Concord Magnum II 260HP Mercruiser 5.7L 21P Laser II prop http://www.concordboats.com/Magnum-II.html |
Do you know if your prop is the same as the other guys? Bow lift can often be the result of what prop your running.
Originally Posted by Sunshadow
(Post 3169409)
| All times are GMT -5. The time now is 11:18 AM. |
