-   -   Penut 454 to EFI mag 454 need help !!! (https://www.offshoreonly.com/forums/do-yourself-boating-budget/235758-penut-454-efi-mag-454-need-help.html)
itsapassion 07-28-2010 09:31 PM
Hello,
Need some help with this project I am doing. I changing out a 454 penut merc with a 454 mag EFI motor. The plug seems to be the same but just looking for a few tips from EFI guys. I hooked up all the same wires to the starter that were off the old starter turned thekey fuel pump went on but did not engage the starter . What wire on that motor engages the starter. Also on the pos side of sylinoind were pos wires go there is a piggy back that has a couple of wires on it any ideas ?
Next issue is the two wires for the drive oiler bottle , I cant seem to find two wires off harness to connect to those.
Next there is a single wire that connects to the intake to a sensore, were does that wire need to be connected to ?
Any tips would be great on this EFI conversion
itsapassion 07-30-2010 08:51 PM
Well what fixed the problem is I tried changing out the solenoid that did not work. What worked was off the small yellow W/ blk wire on solenoid I ran a separate ground wire to the block and boom ! started no problem. The solenoid was not grounded propery. Now I just have to figure out were to plug the to wires off EFI intake to. Hopes this helps someone out in same situation.
