-   -   Transom Rot? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/235868-transom-rot.html)
tackledackle 07-30-2010 02:10 PM
Transom Rot?
Is there a quick and easy way to check for transom rot without hiring a surveyor? I think I read somewhere to use a plastic mallet and tap on the surface. Does that really work?
Any suggestions would be appreciated.
Tim
AngerMgmt 07-30-2010 03:44 PM
A knuckle works fine...............
phragle 07-30-2010 03:47 PM
Somehow...I smirked seeing someone with the name "Angermgmt" talking about using his knuckles on the transom.....
TomZ 07-30-2010 09:19 PM
Use a fist or knuckle to tap on the transom. A short solid return is what you're looking for. It should also be uniform in sound in all areas. A hollow sound amid a solid sound would indicate rot or delamination.
This method would not indicate moisture. You need a meter for that. Just because it's wet doesn't mean it rotted. It does mean that the potential is there for rot to form.
Another good test... Stand on the drives and them trying jumping up and down on them. Observe the transom area while doing so. If you see the transom flex, you've got problems.
Check out http://www.rotdoctor.com for good info and tips.
tackledackle 07-31-2010 12:31 PM
Thank you all!
US1 Fountain 08-02-2010 03:39 PM
Tape a peice of clear plastic to the back, taping the plastic around the edges so it is 100% sealed. Then see if condensation forms on the inside of the plastic after sitting a day or so.
