-   -   500 HP build (https://www.offshoreonly.com/forums/do-yourself-boating-budget/236057-500-hp-build.html)
Eliminator28 04-08-2011 10:02 PM
Originally Posted by Dean Ferry (Post 3371910)
What if you want to reuse the HP500 Steel heads, (running in salt water) and just have them ported and massaged.....
Just finished mine.
Flowed 358 @ .700 int, 231 @ .700 exh.
I blended the bowls, radiused the SS radius and worked the guide bosses on exhaust. Not a lot of work. Left the runners alone.
Put in 11/32 valves (.100 longer)
5 angle intake seats, full radius exh seats.
Milled .010
One thing to remember, HP500 heads are 088's, but are not 118cc. Merc worked the chambers out to 122cc's to keep compression down below 9 to 1. I should get around 575 HP, and over 600lb torque.
Bullet proof motors if done right.
Dean Ferry 04-09-2011 08:29 AM
Thanks for all the data guys, I'm torn between using my present heads, and buying som Alum heads, (concerned about saltwater corrison issues...)
Dean
endeavour32 04-11-2011 03:17 PM
Dean
If you go with Aluminum, have the water passages hard anodized and you'll be fine. I think its about $100 to have that done.
sac 04-12-2011 11:50 PM
I have a HP500EFI Vortec M3 supercharger,EFI,intercooler,pulleys,remapped ECM for sale
[email protected]
Dean Ferry 04-13-2011 09:14 AM
That is a good idea.
Thanks,
Dean
ktm2212 04-14-2011 09:04 PM
I went the 509 ci route which increased compression. Cam, Pro-form 950cfm carb w/ super suckers. Kept stock heads and ended up 589hp. Love the new carbs. Starts and idles like a fuel injected engine
Dean Ferry 04-15-2011 07:49 AM
Really nice #'s for stock heads!:drink:
Eliminator28 04-15-2011 08:53 AM
That's pretty impressive.. Now you have to give us some details. Head work, Cam, etc. Build sheet and Dyno sheet would be even better :drink:
sdodson1 04-15-2011 09:20 AM
:food-smiley-007: More More!
CIG3 04-15-2011 12:52 PM
Tthe Edelbrock (marine) heads are anodized
Marine Duty Performer RPM 454-R
Heavy-duty, 1.89" Inconel exhaust valves provide added durability for marine applications
Hard anodized black to protect the aluminum in the harsh marine environment
Sold with valves only to allow for valve spring choices
Match with an Edelbrock Performer RPM manifold, Performer Series 750 cfm marine carb and Performer RPM cam for proven performance
Smaller-than-stock 11/32" valve stems promote excellent flow and lighter valve weight
