-   -   fuel guage Q (https://www.offshoreonly.com/forums/do-yourself-boating-budget/236621-fuel-guage-q.html)
twistedfun 08-10-2010 09:52 PM
fuel guage Q
my fuel guage decided to quit on me. i checked all connections from the guage back to the sending unit and cleaned them with contact cleaner. they all looked good before the cleaning. what should be my next step in fixing the problem? is there a way to check to see if it is the sending unit or the guage with a multimeter? if so what would be the process? should i just pull the sending unit and check to see if it is just stuck? thanks for any help.
lookinforboats 08-12-2010 07:42 PM
there are three wires on the gauge, 1. purple (12v) 2. black(grnd) and 3. pink(sender) there may also be blue for illumination. anyway check w/ testlight or voltmeter. testlight ground to blk terminal, then tip of test light to purple (should light w/ key on.) if ok jumper blk terminal to sender terminal ( pretty sure its pink) w/ key on and jumped gauge should read full. if not gauge is bad. if ok then jumper sending unit wire to ground - should be same result. if no test light on 1st step find bad ground or 12v
twistedfun 08-15-2010 11:01 AM
thanks. that is what i was looking for.
twistedfun 08-22-2010 10:39 PM
jumpered the sender wires and guage read full. replaced sending unit and all is working. thanks.
lookinforboats 08-23-2010 06:02 PM
your welcome. thanks for the fix info.
