-   -   Runs great for a little while (https://www.offshoreonly.com/forums/do-yourself-boating-budget/238928-runs-great-little-while.html)
douglasp 09-12-2010 08:49 PM
My 99' 252 Boss 454 mpi will run great for about a half hour and then it just falls on its face. It never dies just starts cutting out if I let off to an idle it sounds fine. I let it idle for a couple minutes and then it will take off fine but after a few minutes it does the same thing. I have an extra holley low pres. pump added on. I checked fuel pres. while running on a garden hose, its at 40 psi.....Anyone have any ideas what is wrong?
Fountain4402 09-13-2010 09:47 AM
injectors are dirty, bad fuel
douglasp 09-13-2010 10:27 AM
I drained the fuel tank completely put in fresh gas and changed the filter numerous times,it (the filter) has never had anything in it I could see. Is there anyway to narrow it down to the injectors
firehawkcat 09-13-2010 07:34 PM
Pick up in tanks clogged?
douglasp 09-14-2010 06:46 AM
Ran it last night with a fuel press. gauge installed, when and while it was having its fit the fuel press. was solid at 42 psi. Now I'm thinking its not a fuel problem maybe a coil.
cabin fever 09-14-2010 11:50 AM
Coil would be the next thing I would check.
douglasp 09-15-2010 09:37 PM
Switched ignition coil still have the same problem.....pulled out most of my hair and now I'm wondering what to try next?
douglasp 09-22-2010 09:25 PM
Installed a new pickup coil and ignition module. It threw its fit in about the same amount of time. This time when I backed off the throttle it kept running bad for about 15 seconds then died. 1st time for that. I started it right back up and it was fine for about 15 or 20 minutes and then did it again. It ran bad longer this time then died. I restarted it immediantly and it ran like a charm to the ramp. Anyone know anything else I could look at or try ?
Throttle Fever 09-22-2010 09:49 PM
I had a simaliar issue years ago. Fought it for whole season. It ended being a chunk of crap stuck in the check valve on the tank pickup. Being that your pressure is staying up volume may be down. Next check, the screens in the injectors themself.. Pete
fkboatman 09-23-2010 08:07 PM
TAKE THE GAS CAP OFF AND RE RUN IT, tank may not venting.sucking fuel tank
derekmc1 09-25-2010 07:21 AM
I had similar issues with my 454 (its older than your's 1987) i did everythign, i thought it was losing fuel also I would have dropping revs a sometimes just loose power for periods of time.
Nothing worked until I found out my timing was off 4 deg, new distributor cap, button, and new plugs and wires. while i was working on i found out the main wiring harness was loose and realt dirty inside i cleaned it out too. made a big difference in performance.
douglasp 10-01-2010 09:58 PM
Took the boat to the shop. They found that the longer the boat ran the less voltage there was at the dash. They ran a new 10 gauge wire power wire to the dash and it seems to be fixed. I hope to test run it for myself Sunday......Thanks for the Ideas and suggestions.
Throttle Fever 10-01-2010 10:08 PM
Good deal, glad you got it figured out. Let us know how she works out...
douglasp 10-03-2010 09:30 PM
Test drove today and I believe its fixed. A very expensive piece of wire from battery shut off to the key switch....just glad its fixed......Now where did summer go?
