Fuel bleed question
One of my motors is a serious b@tch to get going. I always need to use starting fluid or crank it forever to get it to fire. It seems as if the fuel is bleeding down back into the tank. Would this be a carb issue (1988 454 330's stock) or a fuel pump? I'm assuming the pump (block mounted) has some kind of one way check valve but I'm just not sure. If this is the case, is there some kind of rebuild kit available? Thanks for your help.
The carb bowls are probably leaking the fuel over time.
Originally Posted by Griff
(Post 3211121)
