-   -   Removing stainless pins from K-Planes (https://www.offshoreonly.com/forums/do-yourself-boating-budget/240801-removing-stainless-pins-k-planes.html)
eightsecmopar 10-14-2010 06:11 PM
Anyone have any luck removing stainless pins from K-Planes that are stuck. Any solvent that works good in loosening from the aluminum? Tried WD-40 and other penetrating oil no luck.
carter38 10-15-2010 12:18 AM
I've heated and pressed them before.
big jing 2 10-15-2010 08:56 AM
take mine out with a slide hammer...Made a rod with 7/16 fine tap, works very well! Ken
eightsecmopar 10-15-2010 09:04 AM
I would have thought that heating would expand the aluminum
FIXX 10-15-2010 05:13 PM
Fixx
+1, with it still attached to the boat! light tap's tho..
Audiofn 10-17-2010 06:59 AM
If you have them off the boat then you can fold them and cut the pins between the two plates with a hacksaw. Then you only have to deal with the smaller sections and it is less likely that you will break off a portion of the allum. tabs. Use heat as well. I tried to press mine out in one piece and broke off one of the ears.
eightsecmopar 10-17-2010 07:11 PM
Thanks I will give that a try
carter38 10-18-2010 12:06 AM
They can be a real pain especially if they've been in salt.
Irishtornado 10-25-2010 01:37 PM
Loaded mine down with penetrating oil and took nut off and used a punch that was smaller than the actual diameter then big hammer while someone else twisted it with a wrench took some doing but it came out...
