-   -   Merc cooling without checkballs and custom hoses? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/242935-merc-cooling-without-checkballs-custom-hoses.html)
spunner 11-22-2010 04:36 PM
I am having a hell of a time retro fitting a couple sets of 496HO manifolds in my Pachanga. Still need spacers to raise the risers - damn collectors hitting the PS pump and t-stat housing... Anyway, the crazy stock cooling hoses and things aren't fitting worth a darn either. After some deliberation, I have decided to move forward with what i think will work fine after researching several other ways people have done this. I plan to split the intake water using a T fitting and go to the top of each exhaust manifold. (backward essentially) From the bottom of the manifold two lines will come to the front of the engine where another T will bring them together into a 2" or whatever size the waterpump intake is. That will then pump through the block and come out the t-stat housing - again just 2 lines which will go to each riser. I am running Alpa so I don't have a sump pump. Anyone done something similar to cleanup the mess and custom hoses? Input appreciated.
Dustin
f_inscreenname 11-22-2010 06:36 PM
Here is mine.
http://img269.imageshack.us/img269/1/83299771.jpg
