-   -   Installing Bellows On B3 Drive (https://www.offshoreonly.com/forums/do-yourself-boating-budget/243080-installing-bellows-b3-drive.html)
ildukhunter 11-25-2010 01:10 PM
Is anybody aware of a good vidio on installing the bellows on the B3 drive. I found some good ones showing how to pull everything off but I have not found any showing the reinstallation. I have to pull off my gimbal ring to correct a steering problem so I thought this would be a good time to replace all the bellows.
FIXX 11-25-2010 01:22 PM
Fixx
their are special tools involved,,the ujoint bellow is easy but their is a tool to install the retainer that holds the drive side of the bellow in place,,,then once thats done you will need the exhaust bellow tool which is a real pain to do because you have to stretch it in place in order to get it to seat in the shield..pm me your number and mabe i will borrow you the tools..
4bus 11-25-2010 05:59 PM
I have the spline socket, bellows expander tool and tube of adhesive for sale if you want them just pm me. I would also recommend a flex drive 1/4 extention and small sockets for hose clamps, makes life easy.
ildukhunter 11-30-2010 04:02 PM
Mrfixall
Did you get my PM?
4bus 12-02-2010 10:11 AM
I will sell you both tools and glue for $65 shipped, and you won;t have to return them. PM me if you want them
Knot 4 Me 12-02-2010 12:29 PM
Or save yourself the trouble and some money and replace the exhaust bellows with an exhaust tube.
bert4332 12-04-2010 08:44 PM
What's the advantage of having a exhaust tube instead of a bellow?
boatnt 12-05-2010 09:52 AM
I not sure what a exhaust tube is,any pictures?
bert4332 12-05-2010 10:30 AM
I looked it up, it's just a straight tube, shorter, and it doesn't appear to have any flex. I read that it misses a lot of the exhaust and your transom gets covered in soot twice as bad. But I haven't read what the advantage is of having one.
http://www.amazon.com/Sierra-Interna.../dp/B0001CLC4K
Knot 4 Me 12-06-2010 10:13 AM
An exhaust tube does not connect to the drive so the exhaust exits straight out the transom plate. Big block and Corsa equipped boats should all have an exhaust tube instead of a bellows.
seafordguy 12-06-2010 10:23 AM
Is the Bravo 3 that much different from the B1? If not then you certianly don't need any special tools. I don't KNOW, but I doubt it is radically different.
Knot 4 Me 12-06-2010 10:36 AM
Installing an exhaust bellows on a B3 is no different than on a B1.
4bus 12-06-2010 10:50 AM
If you guys noticed he was asking about bellows in general, not just exhaust. You DO need some tools to do all bellows, the exhaust only can be done from underneath.
seafordguy 12-06-2010 11:58 AM
I have installed several B1 drive shaft and exhaust bellows with NO special tools and without taking the bellhousing, gimbal ring, or transom assembly off.
