-   -   454 stroked to 496 (https://www.offshoreonly.com/forums/do-yourself-boating-budget/243179-454-stroked-496-a.html)
picklenjim 12-09-2010 09:30 PM
Idleing.
Griff 12-09-2010 09:41 PM
Originally Posted by pantera232 (Post 3270991)
When you guys talk about reversion when does this occur?? With the boat running? ive heard of it when its off
At idle, a cam with a big lope and overlap will suck water back up the tailpipes.
bert4332 12-09-2010 10:31 PM
Would a "silent choice" in the on position prevent that from happening?
jeff1000man 12-09-2010 11:13 PM
Actuallly it makes it worse
jeff1000man 12-09-2010 11:16 PM
Originally Posted by pantera232 (Post 3270989)
When you guys talk about reversion when does this occur?? With boat off or running?
It can happen when you pull back on the sticks to fast, It can happen when that wall of water comes back at the transom when coming off plane. It is most common at idle speeds.
I guess if the overlap was really extreme it could happen at WOT, but you would need a lot of duration.
Cam shaft selection is an art form. I leave it up to better trained profesionals rather than trial and error. There is to much money at stake.
pgolder 12-10-2010 09:42 AM
I run that same set up its a 420 454 bored 60 stroked with dart intakes and lightning headers its awsome.
jeffswav 12-12-2010 07:31 AM
If you are running silent choice, then you definatly have the wrong exhaust for a performance cam. Ditch the silent choice and go with long risers, or dry pipes. I use the EMI thunders, there are a set for sale in the swap shop. Looks like a good deal.
Nevermind, I see that was somone else asking about silent choice.
chevontiac 12-20-2010 08:24 PM
I have rubber connecting the tips to the riser, prolly about 12 inches or so. I will try to post up pictures.
chevontiac 12-21-2010 10:48 PM
http://i243.photobucket.com/albums/f...thunder011.jpg
What do you guys think?
http://i243.photobucket.com/albums/f...thunder010.jpg
jeffswav 12-23-2010 01:06 PM
I am not familiar with those exhaust. But that does not look like a dry pipe system to me. If that is a wet exhaust those risers are to short. It does not look like it is set up correctly to me.
