-   -   383 Stroker kits (https://www.offshoreonly.com/forums/do-yourself-boating-budget/245076-383-stroker-kits.html)
Jtyphoon1 01-05-2011 12:02 PM
383 Stroker kits
Anyone have any experience with purchasing a stroker kit online or at a store? Have a GM 350 that I would like to look into making a 383. Also, need to get headers for thru-haul. Any info would be great!
Boat1 01-06-2011 10:01 AM
How much engine experience do you have. You will need to clearance the block, sometimes rod bolts with a larger camshaft, the assembly will need to be balanced after clearance work is done. It is definately not a bolt-on, going to a 383.
Jtyphoon1 01-10-2011 05:28 PM
I actually build turbine engines for a living and have been messing around with motors for quite a while was just hoping someone had had some good experiences with a site or manufacture.
formula 382 sr-1 01-10-2011 06:05 PM
CNC Motorsports and Competition Products are great to deal with , and good prices !!!! The last set we did had Scat rotating assemblies
andyt25 01-10-2011 06:46 PM
check chs engine they have 383s for 2395 all done with a 7 yr warranty
Jtyphoon1 01-11-2011 07:00 PM
I think I will be useing the blocks that I have.....so just need the "Kit" so to speak. I think just a rotating assembly, Is this right?
andyt25 01-11-2011 07:19 PM
you'll have to have the blocks bored and clearanced for the stroke and the heads redone and no kit you buy won't need some balancing work done it all depends on how much hp you want if you're staying around 400 a cast crank would be fine I used scat for mine most of the kits come with flat top pistons if you use your heads you will need dished to keep the compression ratio down I looked at all the threads on here to get an idea of what parts to use for my hp goals
winterfunguy 01-12-2011 03:22 PM
The SCAT crank kits are decent quality kits for the money. Calies cranks have hardened and treated journals and are of a higher quality craftsmanship but are also much higher in price. Keep the compression ratio in the low 9's don't be tempted by high compressions in a marine engine...it seldom ends well. I would personally not order your kit pre balanced in the event you need to modify the rod bolt heads for clearance issues. I also recomend you have the rotating assembly balanced after you have everything fitted and clearanced...when you are holding your engine at WOT across a lake you will be glad you have it balanced, it is so smooth and vibration free.
Sunshadow 02-08-2011 05:47 PM
I've built a few and by the time you pay for machine work, the one piston that was smaller then the rest, the balancing, and whatever else didn't go quite right you'll end up spending more than you imagined. That 2395 # sounds like a good deal to me.
motorz 02-09-2011 04:22 PM
Scat - Best stuff for the money!
383 9-350-3750-5700-L 2-ICR5700 HYPEREUTECTIC 4.030 DISH 10.4 9.8 9.2 1-91100-1 1-91100 1-91100BIE
fantastixvoyage 02-09-2011 04:39 PM
Typhoon - pm me your contact info. Working up a 383 crate package for champion as we speak.
Mario L. 02-09-2011 08:09 PM
I'm just completing 2 new DART block based 383 engines . . for my Magnum 27.
I chose Eagle forged cranks, Eagle H Beam rods, J&E Pistons, AFR heads, custom cams . .full roller set up.
Everyting needs balancing, very little from your original engine can be reused.
Any 383 at $2395 isn't going to last in a marine application.
Do your research, there's alot involved, from oil pans with adequete clearance to block work and proper rings for a marine engine!
Mario L.
www.VSR1.com
David Stotz 02-09-2011 09:11 PM
What Mario said. I used the Scat cast crank, stock rods SLP forged pistons. Block was taken 40 over so we wound up with a 385. My builder spent days clearencing the block and oil pan etc. because of the large crank. You have to check everything including making sure nothing hits cam lobes. But once done it was worth it!.
