Merc 454
Have a bone stock 89 454 engine... Looking to upgrade a couple things first a stainless marine exhaust system & new carburetor. Does anyone have any suggestions on what carb to go with cfm's etc??
750 holley marine.
Originally Posted by picklenjim
(Post 3327878)
750 holley marine.
Originally Posted by borderline824
(Post 3327910)
What was the stock Cfm?? Are the Edelbrocks any good?
If all you're doing is an exh. and carb. a Holley 750 marine carb is the way to go. You may want to consider an Edelbrock intake (performer/performer RPM or Airgap). |
What HP version of the 454 do you have? 330, 365, etc? Do you plan to do any other upgrades besides exhaust in the future?
If all you are doing is exhaust, you wont gain anything from ditching the stock carb performance wise, and going to a holley you might lose some fuel efficiency. if you have a 365HP version, a cam swap, carb, intake, and rockers can really wake it up. Or better yet, slap on a small 177 or 250 supercharger. |
Originally Posted by MILD THUNDER
(Post 3327949)
(Post 3327962)
I have the 330 version not the mag. Could you put the supercharger on the stock engine??
You'll notice small gains from everything that you're doing. To really notice a big gain though, you're going to have to do more. Cams would make a big difference too, but you'll likely have to pull the motors, but you have to decide if you want to take on that sort of commitment. |
**Edit (the edit function won't work for some reason)
That's supposed to say "Edelbrock Performer RPM intakes" not "heads" if you upgrade your heads to large ovals. |
Some guy have put blowers on your motor with the stock cast internals, and have had good luck. It would probably be ok with low boost, good fuel. the cast pistons wont hold up to any detonation as good as a forged piston. Personally, i wouldnt do it.
I wouldnt go crazy spending a ton of money on your motor. Leave it stock, and save up some dough. Then, when your ready, you can buy a nice motor, and sell off your stock one. Trust me, it will be cheaper that way! |
(Post 3328008)
You get to a point with these 330s where you're better off just buying a 370-500hp Merc motor used, and doing a refresh on it before you put it in. You can pick up 50ish Hp and 5ish mph out of putting new heads, intakes, carbs, 1.7 roller rockers, exh., etc. on them, but you still have a tired cast internal motor, and to make any real power you have to change the cams anyhow. If you're pulling the motors and changing the cams, you're better off doing a motor swap. The single biggest power adder, if you want to keep it cheap, is changing the heads. The peanut port heads are the biggest power drain on that motor. You could upgrade the heads, intake, carb for less than the cost of the Stainless Marine exh. manifolds. If you're not willing to make the commitment to change the motor completely you'll be better off swapping everything but the exh. If you want to later swap the motor the Stainless Marine exh. would likely be the only thing you want to use off of your old motor (aside from accessories). You just have to figure out how far you want to take it. |
Originally Posted by wjb21ndtown
(Post 3328133)
You ain't kiddin...
Im beating my head on the wall now waiting for my 454 to be back from the machine shop, ill let you know what happ with new cam, intake, .040 pistons, and 781 heads, i already had 750 holly ssmarine exhause and edlebok intake...
Originally Posted by pantera232
(Post 3328376)
I wouldn't bother with getting an intake for those peanut port heads if you're going to get a new motor later. If you want it to look pretty for a while by painting the new intake a diff color, or if you just want to pull everything and put it back together new that's one thing. However, if you're looking for a performance gain you probably won't notice much by just putting a new intake on it.
The Stainless Marine Exh. will probably net you 15-20 hp at best (which is 1-2mph), but don't worry about that. It will really help once you put a 502 between your new manifolds. |
Alot of mention of peanut port heads, is this definately what he has? I would suggest pulling a valve cover and getting casting numbers to see which heads you have. If they are large ovals, you would have alot of potential with your motor, and depending on your application, possibly even better off than with rectangle port heads.
with 2 weak cylinders i was running 58 with a 21 pitch prop, still waiting on engine back and bob to build the cam every one seems to be in slow motion even considering were in a recession here in s fl
| All times are GMT -5. The time now is 06:34 PM. |
