-   -   RH rotation 454 RM seal help (https://www.offshoreonly.com/forums/do-yourself-boating-budget/249087-rh-rotation-454-rm-seal-help.html)
88BFN 03-09-2011 06:03 PM
Hello,
First off I’m not really an Offshore only guy but do have a love for the water. I’m rebuilding a 1988 Correct Craft Barefoot boat.
I have reverse rotation 1988 PCM 454 and the 2 piece rear main seal so far is discontinued.
I’m searching for a trick, conversion or a source other than the following
PCM Marine
Sierra Marine
Fel-Pro Marine
All of the above are telling me that it is no longer available.
From what I have read some of the twin engine boats are reverse rotation engine and some are done via an out drive/transmission.
Is there anther manufacture ?Volvo, Merc. ect.
Thanks in advance Jeff
anchor 03-09-2011 06:54 PM
i ran into this problem last year. i was able to locate 6 seals. i have 4 left. the original part # from merc is 26- 75980. 2 piece rear main seal. if interested, send me a pm.
FIXX 03-09-2011 07:05 PM
Fixx
felpro still makes it,,yellow in color if i remember correctly..
also you will need the crank seal too!
http://www.fastengineparts.com/produ...ew.php?id=1011
88BFN 03-09-2011 07:12 PM
Crank seal? for the time cover?
Im told that Felpro no longer makes /has these
tunertech 03-09-2011 07:19 PM
The listed site will try and download a trojan/virus if you go to the site.... beware. It is infected.
88BFN 03-09-2011 07:24 PM
Thanks a little late though
