-   -   Oil/power Steering Cooler Help!!! (https://www.offshoreonly.com/forums/do-yourself-boating-budget/249431-oil-power-steering-cooler-help.html)
92stingray502 03-15-2011 08:36 PM
Please help me guys!! Im rebuilding a 502 due to a wiped flat tappet cam. I know i have to replace the oil/power steering cooler and im pulling my hair out trying to figure out what to replace it with. Merc says the OEM replacement is a 817577t. This cooler is crazy expensive. I have a 23 foot boat and I will be under 600 hp. Do I really need a cooler this big? I have been told that you can't clean the metal out of the cooler. Someone please help!!!!!!!!!
1BIGJIM 03-16-2011 06:18 AM
I am pretty sure this is the one I used on my 502 with the power steering. Worked great. Longer than stock, but I was able to use the same mounting brackets.
http://www.cpperformance.com/p-13321...ot-length.aspx
Same one, but $100 cheaper.
http://www.offshoreonly.com/forums/s...rts-bravo.html
ezstriper 03-16-2011 10:04 AM
the factory merc stuff has different ends on them...if you have to change everything I think to up grade...doing that now...have all the stock stuff if needed, but mine is a gen VI, note sure if there is a diff..don't think so...
92stingray502 03-16-2011 10:26 AM
Are you saying your replacing ur stock setup? If so what did you have for stock?
Griswald 03-16-2011 10:39 AM
I have a stock cooler from 502MPI if you're interested.....
92stingray502 03-16-2011 10:45 AM
Send me a pic [email protected]
1BIGJIM 03-16-2011 12:08 PM
I just reread your original post. You said "under 600 hp"
Yes you are going to need a bigger cooler.
Look at the two links I posted above. The only difference is they need a 3/4 to 1/2 bushing to run your original lines. They have 1 1/4 water inlets. I had to cut my hoses shorter because the cooler was longer, other than that they bolt right up.
The used one even had the oil line and fittings.
92stingray502 03-16-2011 12:17 PM
The cooler my motor had on was a 3in x 20in. Do I need something that big?
92stingray502 03-16-2011 12:38 PM
i looked at the one that you posted the links to. those arent oil/power steering coolers. those are oil only. even though that is a good deal with the lines.
92stingray502 03-16-2011 07:14 PM
I just look at my instrument cluster and I don't have a oil temp gage. Do I need to install one?
jeffswav 03-17-2011 07:51 AM
Here is the one I use, you may want the slip on fittings, I use AN on everything so I use the threaded ends. http://www.eddiemarine.com/store/car...l&p=13577&c=47
Eliminator28 03-24-2011 04:50 PM
If it just has stuff plugging the holes inside, you can clean it out. I just did mine, it was full of lot's of neat debris :eek:, old impeller pieces, sand etc.
I used a piece of Solid Core 14 Gauge wire (with the sheathing on it), wrapped a piece of electrical tape around the end and carefully went through each hole cleaning everything out. Pressure test it when your done.. good to go :drink:
Just realized your probably talking about metal on the inside of the oil part of the cooler.. At the cost of new ones, I'd sure try flushing it out if you think it would work.
92stingray502 03-25-2011 09:43 AM
No flushing it will not work. There is no way to get all the metal out of it unless you cut it open to clean it. I'm think I'm going with the one from Eddie Marine it has the best price. Thanks guys.
Mr. Cool 03-29-2011 12:14 PM
You have this possibility
http://www.mrcool.us/817577t-mercrui...em-cooler.html
or this one
http://www.mrcool.us/mrc-cph-650.html
depending on your horsepower.
If you want to give us a call, I'm sure we can help.
248-960-7850
Russ
