Whats does it take to make dry tails?
Well if this new law goes into effect in missoui looks like were gunna need mufflers at lake of the ozarks..but on other lakes I run there is no sound restriction. So my question is, since Im gunna have to buy slip on mufflers anyway, how can I make my tails dry on my boat? I have emi thunders. I love the sound of dry tails over wet anyday..so I might as well go for it..I know Ill have to have someone weld extentions on my tails now to extended them through the transom..but what about the water?
Well looks like all you really need to do is disconnect the hose where the water goes in to the tail and run it to dumps going through the transom. I don't know what boat you are doing this in but keep in mind the tails are going to be getting very hot. Will this be safe in your boat?
If you are going to make this change because your worried about reversion with that HP500 cam with 110 LSA than you may want to concider just selling that cam and get a crane 139011 or 168731, same cam for different gens. It's almost the same specs as the HP 500 except 112 LSA. Personally I favor the crane. It would be cheaper and a lot less work also. Just saying. Just my opinion. It's your boat. |
Originally Posted by picklenjim
(Post 3356976)
Fixx
Originally Posted by stlliberator
(Post 3356851)
(Post 3356976)
If you are going to make this change because your worried about reversion with that HP500 cam with 110 LSA than you may want to concider just selling that cam and get a crane 139011 or 168731, same cam for different gens. It's almost the same specs as the HP 500 except 112 LSA. Personally I favor the crane. It would be cheaper and a lot less work also. Just saying. Just my opinion. It's your boat. If you have a good welder who is good with stainless, they should be able to do it. Like Mr. Fixxall says, you can either weld bungs to the tails and dump the water from them overboard with a thru hull dump. You would need to mount the bung close as possible to the inside of the transom. Or, you can just let the water dump at the very end of the tails. You would need a length of 4" stainless pipe, and 3.5" pipe. You would cut a little bit of the 4" pipe you have on your existing risers back far enough to gain access to weld your new 3.5" pipe on to the old 3.5" pipe. Once that is welded up, you can slip the 4" pipe over it, and then weld the two 4" pipes together. At the end of the tails, you will need to make little 1/4" spacers that you can tack weld in. It will keep the 3.5" pipe centered within the 4" pipe. Once the front side is all welded up, you can then tack weld the exit side up. You can make the little spacers at the 12,3,6, and 9 oclock postions. Water will exit the exhaust around those little spacers. Im sure that sounds confusing as hell, but its really a simple idea once you get the picture. Im prob just explaining it like crap. :drink: |
pics would be helpfull..lol just saying..im gunna call emi tommorrow and see how much it would be to convert my tails..if I gotta run mufflers at loto..then I might as well be loud when I can..:evilb:
| All times are GMT -5. The time now is 10:52 AM. |
