-   -   Wire harness extension (https://www.offshoreonly.com/forums/do-yourself-boating-budget/250406-wire-harness-extension.html)
Itsallgood995 03-30-2011 10:27 AM
I'm converting my OMC to Merc. Both the OMC harness from the gauge & the Merc harness are a 10 pin round connector. Problem is I need an extension between the 2 harnesses. Anyone know of a prefab extension or will I need to splice & extend the wires?
FIXX 03-30-2011 10:49 AM
Fixx
take a look around the shifer of the boat,,sometimes the mfr weill loop the harness..
Itsallgood995 03-30-2011 01:10 PM
The harness is routed through a PVC pipe in the floor. I'm fairly positive there isn't enough slack under the dash but I'll take another look.
MILD THUNDER 03-30-2011 03:16 PM
Try these guys
http://www.marlanindustries.com/imag...an-Catalog.pdf
Itsallgood995 04-01-2011 01:29 PM
Tried a bunch of different leads & no one has exactly what I need. There are pigtails that I could splice into either end of the harness but no 10pin round extensions. Since I'll need to splice into either end anyway the cheapest option would be to get a 3' section of harness with the appropriate wires/ gauge & colors. Anyone have an old wire harness I could get a section of?
[email protected]
offthefront 04-02-2011 06:32 PM
http://www.perfprotech.com/store/cat...iser,5957.aspx
motorz 04-03-2011 02:12 PM
Talk to JIM or Bill
Originally Posted by MILD THUNDER (Post 3364006)
