-   -   Spark Plugs And Timing (https://www.offshoreonly.com/forums/do-yourself-boating-budget/254106-spark-plugs-timing.html)
MEDIUMPIMPN 05-21-2011 11:23 PM
What Spark Plugs Are You Guys Running On Your Blown 540's And What Timing??
ezstriper 05-22-2011 08:34 AM
kind of a loaded question..what blower...cooler ? fuel system ?
MEDIUMPIMPN 05-23-2011 07:39 AM
Stock Efi, 4-5 Lbs, M1 Procharger
ezstriper 05-23-2011 01:34 PM
hope you have a good retune on the ECM....ac 42 on the plugs, I would get the timing at full advance 26-28..but there is a lot of variables there...from what Ive seen the stock EFI may be a big issure with what you have....I'm running a M3 ona 509, just took off the EFI went to a carb...to much B/S with trying to get the ECM tunied right...some get it right...some don't...if you don't very bad things happen..
Turbojack 05-23-2011 08:01 PM
What Heads?
You say stock efi, what engine was it stock on? What was HP of engine?
