Power Steering Pump compatibility question
Will a MerCruiser power steering pump PN 16792A39 for a 454/502 MPI work in place of a PN 90507A12 for a 350/260 Small Block ?
This is one for the MerCruiser parts experts out there. Thanks in advance. |
i looked it up on bammarine.com and came up with the same part numbers.......where did you get the other number??
Originally Posted by ballon78
(Post 3414714)
My question is what is the difference in the 2 pumps. I am thinking that yours is the big block pump. |
if there is any question change the pressure relief valve/spring, the big nut under where the high pressure line connects, just take that off, the valve and spring pop right out, swap them and you will have the same as before...you can do the same thing buying a std saginaw pump from a auto parts store...
mine is from a big block, thats why i wrote from a 502mpi on the swap shop.....it will work with yours, there all the same.
| All times are GMT -5. The time now is 12:06 PM. |
