How to's needed
I have a water leak into the bilge. Looks like it is coming from the fitting that the sea water inlet hose attaches to at the transom. Is this a pain to fix? suggestions?
Is it on like a bravo drive or a pickup that is on the transom?
Yeah, Sorry. its a bravo 1 drive .
the leak , best I can tell, is coming from a metal fitting that the water intake hose is connected to. Not coming from the hose, but, somewhere before that. |
If you can get to it, it shouldn't be a pain to fix. On a Single Application you might be able to get down there. On a twin it could suck.
The piece is plastic so it could have developed a leak - it is a barb fitting that mates up to the inside of the transom. I think there are 4 bolts that hold it in place (IIRC). |
OK, after looking even closer. the intake hose connects to a metal fitting somewhat like a thermostat housing at the transom. the leak I'm seeing is coming down onto this area. Is it possible that the leak could be coming from the trim sender wires where they come thru the transom? This is so frustrating !!!!
Just out of curiosity, have you checked your Shift Boot and U-Joint Bellows? They're normal replacement items and only last 3-5 years under the best of conditions. When they rot out, they leak in that area. They're also a heck of a lot more common causes for a leak. Generally speaking, if either of them is the problem, the leak will get worse when the drive is turned to one side or the other and / or if it is trimmed up.
Originally Posted by Too Stroked
(Post 3419474)
Just changed all the bellows last year, along with the gimble bearing , u joints and trim sensors. Thats why this leak is frustrating me so. I have'nt tried turning the drive to see if it gets worse though, maybe that will help narrow it down. |
If the leak is above the water neck fitting it could be the wires or more a chance the tiller pin seal is at fault.
Mac |
Originally Posted by NOPUN
(Post 3418527)
If it's like mine you have a c-clamp on that hose...mine is a PITA to get to but requires a twist occasionally. I was able to get a cheap battery screwdriver with a hex bit and position my self over and between the engines and tighten mine. What helped me was having a light buit into the screwdriver so I could find the target. Good luck with this. |
Could be the gasket to the neck piece that the hose connects to.
Part #21 in the diagram. http://www.perfprotech.com/store/ass....aspx#assembly |
| All times are GMT -5. The time now is 03:07 PM. |
