-   -   Which oil pump when rebuilding a 454 (https://www.offshoreonly.com/forums/do-yourself-boating-budget/259311-oil-pump-when-rebuilding-454-a.html)
Dennis Moore 08-23-2011 10:55 AM
Also, you mentioned the guys at the local boat shop talk about the "Heavy Duty" oil pump.
GM calls the #3969870 oil pump the "Heavy Duty" oil pump.
Dennis
FIXX 08-23-2011 04:45 PM
fixx
Dennis
I guess you never used a 10778c melling pump..I bet if you saw how much better it was made you would change your mind..
excal82 08-23-2011 05:59 PM
fixx
that pump #says race only??? have you used them and how many hrs are on the ones in your engines. dont mind spending the extra $$ but i also want to kn ow this thing will go the distance
Raylar 08-23-2011 09:59 PM
No Brainer!
We have built many engines in our shop in the last 10 years and the 10778 series Melling Select oil pumps are the only ones we use. NO Problems, No Failures and NO Unhappy Customers, take it for what its worth use that pump!
Best Regards,
Ray @ Raylar
FIXX 08-23-2011 10:09 PM
fixx
they work awsome and no failures.. no? ray has the perfect answer
Borgie 10-22-2013 11:06 AM
Bringing this back. I'm building a 496 stroker with stock oil pan (Gen V) and windage tray. Would the melling 10778 be appropriate for said application? No I don't want a aftermarket 14 quart pan and I'm using a large oil cooler. Thx
