Broke off top of dip stick
Last weekend I went to check the oil on my 525efi and the yellow knob broke off the end of the dip stick. It is stuck in the tube about a 1/2 inch down. Several attempts to remove it were unsuccessful. Looks like I will need to remove the tube going to the bottom of the motor. Looks like this tube is pressed into the block just about the oil pan. How do I remove and reinstall it?
Thanks! |
Had the same thing happen to me. I was able to get it out with needle nose pliars, should be able to grab on to the end up the dipstick that protrudes into the yellow rubber nob. I've also heard you could use a shop vac and try to vacuum it out. Might also be able to get a very small screw driver, heat it up and push it into the nob so that it melts into the rubber and pull it out.
1 Attachment(s)
Get yourself a pair of foreceps. I've got a pair like this and it's been invaluable for all kinds of difficult situations like yours.
Originally Posted by CigDaze
(Post 3497642)
can you make a loop out of fine wire and fish it down the tube and draw the loop tight and pull the dipstick out of the tube?
Had a friends break off in a 700SCI was able to get it out using a sharp 45 deg angle pick.If you can't grab it like Tex said heat it let it melt in there a little,you then have hole to insert pick then pull.
Thanks for the great ideas.
Try drilling a very small hole in the center and screwing a drywall screw in there and then pull it out. I work at an auto repair shop and we have had to do this on GM cars before.
Got it out! Used a fine thread self taping screw. I was able to get it to grip into the rubber so I could pull it out. Thanks for all the great ideas!
just pull the tube out..the push the stick out from the bottom...
| All times are GMT -5. The time now is 08:05 AM. |
